28May: Waving goodbye to AR12824/12826
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Everyone.
Here are some H alpha images of the disappearing ARs taken with the C8 Edge / Daystar 0.6QPE system at about f/30. There are two on-band images taken with different camera gamma settings. A slightly less contrasty gamma was used to try and capture the two surges evident in the picture. In the more contrasty image (taken ~20 minutes afterwards), there was some interesting streaming between the two spots in AR12826 (at the limb). The off-band image was taken at a detuning of ~0.8 angstroms to the blue, showing a number of Ellerman bombs. Seeing was mediocre so detail is lacking but it was my only "kick at the can".
Peter
Peter
- Has thanked: 9144 times
- Been thanked: 6025 times
Re: 28May: Waving goodbye to AR12824/12826
A beautiful set of images, Peter: the off band is very interesting also. Well done !
- Been thanked: 16691 times
The off band image really shows the spicules well!! I see a couple of Ellerman bombs in there too.
- JochenM
- Been thanked: 1619 times
Excellent shots for such a seeing conditions. Contrast in the Ha core is my favorite. And the off-band image is very illustrative.
BTW. Have you ever think about adding about 0,7A Lunt LS50FHa etalon (not a mini red colored version)? Such a double stack helps a lot against mediocre seeing. I believe that in a visual mode it will be a killer combination.
The images are very good Peter, quite informative and helpful with the descriptions. Thanks.
Phil
Phil
- p_zetner
Thanks everyone.
Valery: I have had lots of frustration trying to double stack the Lunt LS50FHa with the Daystar Quantum. I’ve tried numerous optical configurations (collimated beams, telecentric beams) and have always been plagued by banding from the Lunt. Almost ready to give up!
Peter
Peter
PM sent.p_zetner wrote: ↑Sun May 30, 2021 7:37 pm
- Been thanked: 4786 times
- Has thanked: 6181 times
- Been thanked: 7142 times
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Fantastic Peter!
And despite the seeing.
Alexandros
Alexandros
Alexandros
Greece
Greece
