Okay seeing, hadn't been out for a while so good to get the scope out again. Full disc imaged, as well as the departing sunspot. As is customary I've gone for more magnification than my seeing really allows for:)
Also, I've really enjoyed all of ya all's shots of this region over the last several days! Always nice to have them available when I can't get out myself.
Full disc image is lunt 100ss with asi294mm and ROI, partial shot is asi294mm+4x telecentric+ROI, both images using best 25% of 500 frames.
Full disc and departing sun spot from the 29th of May
- AJamesB
- Has thanked: 1154 times
- Been thanked: 630 times
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Has thanked: 17860 times
- Been thanked: 17004 times
Re: Full disc and departing sun spot from the 29th of May
Very nice.
Look a bit to the northeast in your full disc images and you will see a new plage there. Hopefully it will grow.
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Nice set of images despite the challenging conditions.
- AJamesB
Fingers crossed, the more activity the merrier!DeepSolar64 wrote: ↑Sun May 30, 2021 2:02 am
asi178mm
asi294mm
asi178mm
asi294mm
- Has thanked: 8559 times
- Been thanked: 8297 times
Good images. The little plage region does seem to be developing nicely.
