23 May H-Alpha animated gif on AR2824 (CAK images added 4Jun)
- yltansg
- Has thanked: 1455 times
- Been thanked: 1444 times
The weather has been poor over the last week.
Finally found some time to process the video recordings taken on 23 May 21. The object was AR2824 . The imaging jig was a C11 fitted with an ARIES D-ERF (used at full aperture) and a Daystar Quark Chromosphere. Overall I made 37 recordings from 9:30 to 10:05am local time. I made the following animated gif from 33 good recordings:
This was how a typical single frame looked like:
I am happy to see the evolution of the various filaments and fibrils. What other solar features can you make out from the animation?
You can do a right-click to see the gif in full resolution.
Alfred
Alfred
- Has thanked: 9318 times
- Been thanked: 6155 times
Re: Hi-Res H-Alpha animated gif on AR2824 (23 May 21)
Definitely seeing the flaring, Alfred. Lovely animation and stills.
Wow!! to get seeing that good for so long is a miracle
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Nice animation, Alfred.
Some spectacular high resolution details in the two images.
Peter
Peter
- yltansg
Re: Hi-Res H-Alpha animated gif on AR2824 (New variant added)
I have added a 150ms delay between frames and make it non loop so that the reader can have better control to see the evolution of various features in the half hour duration:
You can do a right-click to open the gif in a new tab and click on "reload this page" to start the animated gif to see the development of each feature of interest.
Comparing the 2 version, which one do you prefer?
Hope to hear from you.
Thanks.
Alfred
Thanks.
Alfred
- Been thanked: 4980 times
Alfred:
Beautiful work all of it.
- Has thanked: 6305 times
- Been thanked: 7322 times
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Stunning animation in Hi-Res Alfred!
You won against the seeing!
Thanks for sharing,
Alexandros
Thanks for sharing,
Alexandros
Alexandros
Greece
Greece
- rcwinter
- Has thanked: 191 times
- Been thanked: 265 times
Hi Alfred
Cracking animation and HR images
Kind regards
Kind regards
Baader DERF 90 & 160. Vixen SP102M Moonlite, Takahashi TOA130 Feathertouch 3.5, Takahashi FSQ106N, Daystar Quantum SE .4ang, Apollo Max, ZWO ASI 174MM. 2600mm, 178MM, Lumenera Skynx & Infinity 2
- Been thanked: 1735 times
Hi, Alfred
I always look forward to your work and this is no exception.
How do you get the linear features in your image to be so smooth? Is it through stacking many frames or is it the result of very good seeing ?
Lou
Lou
Amazing animation! I don't remember if anyone has the same scale animation of the sunspots active group in Ha. A lot of high res pictures - yes. But no such detailed animation.
Congrats, Alfred and thanks for your efforts and sharing this with us. And, please, continue to post them again.
Valery.
Valery.
- yltansg
Thanks, Franco, Alexandra, Peter, Eric, Arne, Alexandros, Richard, Lou and Valery for your kind comments.
My C11 has been on the CEM 60 mount in the garden, under 3 layers of covers when not in use. It has been there for 24 months. Our weather is humid, hot with lots of rain. I should be seeing some deterioration of the Optics soon
Alfred
Alfred
- yltansg
Hi Lou,
I do very little pp, mainly due to my poor knowledge and lack of effort to learn to improve my skills. In the hands of an expert, I believe much better images can be derived from the video recordings.
From Valery, I learnt to capture the video with low exposure (to freeze the seeing) and low gain (less noisy). All 33 videos were recording with:
Exposure: 3952 µS
Gain : 25232
Camera: Basler acA1920-155um
From Alexandra, I learnt to apply denoising at the earliest possible stage of the post processing. I use Neat Image for denoising.
In Photoshop, I only adjust level and contrast. That is all
Alfred
- yltansg
Dear Alexandra,
I did not realise how good the seeing was. In all, 33 out of 37 recordings were used to produce the animated gif. I ought to be grateful for good seeing. The following is one of the 4 images that I did not used.
Many features cannot be seen when the seeing get worse.
Alfred
- yltansg
Going through the recordings, I see some other images taken on the same day:
I will be posting more soon, including CAK images.
Alfred
Alfred
- Has thanked: 20813 times
- Been thanked: 10480 times
Re: 23 May H-Alpha animated gif on AR2824 (New added 3Jun)
You certainly did have some good seeing that day Alfred
- yltansg
By the time I started CAK imaging it was 10:30am local time and the seeing had gone south. Here is two of the better images taken with the same C11 with a 9" mask and a pair of Alluxa filters fitted in a skybender:
stacked 25 frames from a 2000 frame recording,
Stacked 40 frames from a recording of 2000 frame recording, With light processing
Alfred
Alfred
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Re: 23 May H-Alpha animated gif on AR2824 (CAK images added 4Jun)
Great images Alfred, nice resolution
Pedro Re'
