Heads Up 30th May
Stardust5858
Has thanked: 803 times
Been thanked: 1182 times
Heads Up 30th May
Post by Stardust5858 »
Hi all, the sun never stops at surprising us does it with two new AR's. Numbered AR2827 and AR2828. Have a lovely bank holiday weekend folks.
Screenshot (86).png (1.16 MiB) Viewed 315 times
Screenshot (88).png (825.11 KiB) Viewed 315 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: Heads Up 30th May
Post by EGRAY_OBSERVATORY »
Yes Ella. that is correct, so the AR's keep coming for you to capture.
Thanks vm
Stardust5858
EGRAY_OBSERVATORY wrote: Sun May 30, 2021 2:08 pm Yes Ella. that is correct, so the AR's keep coming for you to capture.
Thanks vm
Thanks Terry, I was expecting a quiet sun, but it's brilliant we've more active regions.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Stardust5858
I'm loving my triple mounted solar setup. Long time in setting it all up together but worth the wait.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
MAURITS
Has thanked: 2462 times
Been thanked: 4878 times
Post by MAURITS »
Ella, nice to see the images of the new AR's.
What a BEAUTIFUL equipment for solar observation and imaging 😉👍
Maurits
Vista del Cielo Observatory
www.vistadelcielo.be
Has thanked: 17807 times
Been thanked: 16944 times
Post by DeepSolar64 »
What a nice setup!! All scopes pointing at our wonderful star!!
Stardust5858
Thanks Maurits and James. It's been a goal of mine to triple mount for the three wavelengths of HA, CaK and White Light. Making life imaging the three wavelengths so much easier.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Martin_S
Has thanked: 999 times
Been thanked: 3060 times
Post by Martin_S »
Hi Nigella, thank you for sharing your imaging setup with us, it looks great.
Martin
Stardust5858
Martin_S wrote: Sun May 30, 2021 8:46 pm Hi Nigella, thank you for sharing your imaging setup with us, it looks great.
Martin
Thanks Martin.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Hello Nigella
I agree with Maurits you have very nice equipment. Thanks for the screenshots, they help a lot.
Ivan
Stardust5858
Ivan wrote: Sun May 30, 2021 9:24 pm Hello Nigella
Ivan
Thanks Ivan, glad to help.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
