Heads Up 30th May
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Heads Up 30th May
Hi all, the sun never stops at surprising us does it with two new AR's. Numbered AR2827 and AR2828. Have a lovely bank holiday weekend folks.
- Screenshot (86).png (1.16 MiB) Viewed 319 times
- Screenshot (88).png (825.11 KiB) Viewed 319 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Re: Heads Up 30th May
Yes Ella. that is correct, so the AR's keep coming for you to capture.
Thanks vm
Thanks vm
- Stardust5858
Thanks Terry, I was expecting a quiet sun, but it's brilliant we've more active regions.EGRAY_OBSERVATORY wrote: ↑Sun May 30, 2021 2:08 pm Yes Ella. that is correct, so the AR's keep coming for you to capture.
Thanks vm
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
I'm loving my triple mounted solar setup. Long time in setting it all up together but worth the wait.
- IMG_20210530_135726.jpg (2.49 MiB) Viewed 307 times
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 2501 times
- Been thanked: 4924 times
Ella, nice to see the images of the new AR's.
What a BEAUTIFUL equipment for solar observation and imaging
- Has thanked: 17949 times
- Been thanked: 17093 times
What a nice setup!! All scopes pointing at our wonderful star!!
- Stardust5858
Thanks Maurits and James. It's been a goal of mine to triple mount for the three wavelengths of HA, CaK and White Light. Making life imaging the three wavelengths so much easier.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3061 times
Hi Nigella, thank you for sharing your imaging setup with us, it looks great.
Martin
Martin
- Stardust5858
Thanks Martin.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Ivan
- Has thanked: 3500 times
- Been thanked: 2285 times
Hello Nigella
I agree with Maurits you have very nice equipment. Thanks for the screenshots, they help a lot.
Ivan
Ivan
- Stardust5858
Thanks Ivan, glad to help.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
