High Magnification White Light
- Has thanked: 1075 times
- Been thanked: 1986 times
Seeing wasnt really what it claimed so I keep trying to get sharper images but so far there results are not too disappointing.
Mix of 5x and 10x powermates (2x + 5x)
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Re: High Magnification White Light
Lovely granulation, thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
That's amazing Simon, what scope were you using?
Martin
Martin
- Has thanked: 9319 times
- Been thanked: 6157 times
- Has thanked: 17849 times
- Been thanked: 16992 times
Amazing work Simon. Very nice granulation images. Superb resolution! I love them!!
Oooh!! mouth-wateringly beautiful don't you just love a good carpet of granulation
- Stardust5858
Fantastic captures Simon, loving the granulation, thanks for sharing.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 8558 times
- Been thanked: 8290 times
Superb, Simon. Excellent views.
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7323 times
Excellent granulation images Simon!
Thanks for sharing.
Arne
Thanks for sharing.
Arne
- Has thanked: 1640 times
- Been thanked: 878 times
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Wow!!!!!
Stunning granulation Simon!
If this is with 'poor seeing' then what will you be producing with a good one?
I cannot have good results with Barlow x2, and you are using x2x5???
I did not even now it is possible without bluring completely the image.
You give me hope that with the FFC on hand I may finally see Hi-res granulation.
Thanks for sharing.
Alexandros
Thanks for sharing.
Alexandros
Alexandros
Greece
Greece
Im starting to figure out how best to shoot for this level of details, next test is the 12" newt full speed ahead gimme all dem photons. I might have a window thursday but i rly need 5/5 seeing! Who knows, i might get lucky.
It wasnt poor seeing, it was reported 4/5 but looked more like 3/5 with short moments of clarity but not long enough. On average i was getting maybe 30-40 frames of rock solid data and the rest of the 700 frames are just junk.
H-Alpha wrote: ↑Mon May 31, 2021 11:17 pm Wow!!!!!
Thanks for sharing.
Alexandros
Almost forgot....
Here's one that went through Topaz but now im getting into the point where the final image is somewhat questionable in terms of data accuracy since its now considered being heavily processed. It's starting to look a little odd.
This last one looks like an image from a professional solar observatory, Simon. Very impressive !
- H-Alpha
Franco is right Simon!
It may be slightly overprocessed, but your result is fantastic!
What was your seeing. You wrote not as good as predicted, but do you have any idea? No SSM I suppose.
Anyway your powermates should be the best ever produced! ;-)
Alexandros
Alexandros
Alexandros
Greece
Greece
No SSM, i wasnt measuring to be honest. Seeing was rated at 4/5 but was more like 3.5/5
Overprocessed is probably an understatement. Its WAY over. Since this is still new to me and im not getting consistent results, I still need to figure more things out. Trying to get some time on a 230mm refractor.
H-Alpha wrote: ↑Wed Jun 02, 2021 11:43 am Franco is right Simon!
Alexandros
