31May2021: AR12827 in Hi-Res H-alpha
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Hi Everyone.
I was able to take advantage of a short period of above average seeing this morning. Here are some high resolution images taken with the Celestron Edge / Daystar 0.6QPE system at ~ f/46. Some inverse images are presented as well as an off-band shot (~ 0.6 angstroms blue).
Peter
Has thanked: 9296 times
Been thanked: 6130 times
Re: 31May2021: AR12827 in Hi-Res H-alpha
Post by ffellah »
Pretty amazing close ups, Peter ! I had to limit myself to wide field views this late afternoon. Well done.
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Very nice close-ups Peter! They show an impressive amount of detail!
AstrOdyssey
Has thanked: 64 times
Been thanked: 91 times
Post by AstrOdyssey »
Nice setup and good capture, very detailed penumbra area. thanks for sharing, Peter.
Clear Sky & Regards
Stephen
Has thanked: 8523 times
Been thanked: 8253 times
Post by Carbon60 »
Very nicely done, Peter.
Superb images.
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Hi Peter
It turned out great.
I really liked the inverted shot.
And what does the shift of the stripe to the side of the blue wing give? A less dense layer of the chromosphere? And it seemed to me (or not?) That the areas with higher temperatures became more contrasting?
Sorry if the questions are stupid.
Ivan
p_zetner
Post by p_zetner »
Thanks for the kind comments, everyone.
Ivan, as you progress from line core to line wings you image closer to the photosphere. I don’t think there’s necessarily a higher contrast in high temperature areas. This is a pretty active region and it changed its “look” over the course of the imaging session.
Peter
Ivan
Post by Ivan »
Thank you for your answer, Peter.
Has thanked: 17925 times
Been thanked: 8894 times
Wow!! what aperture was this? I can dream :hamster: :bow
p_zetner
Post by p_zetner »
Hi Alexandra.
I imaged with the C8 Edge (200mm).
I did luck out with the seeing.
Thanks for the comment.
Peter
eroel
Been thanked: 4958 times
Post by eroel »
Peter:
Super images.
Like all of them.
