2021-06-01 - AR2827 med res (HA/WL)
- JochenM
- Been thanked: 1619 times
An almost summerlike day here today (how fast things can change!). Seeing was actually pretty good as well, so decided to try and go for some higher res work. HA/WL came out quite nicely, CaK ended up being a blurry mess. Two out of three; I'll still take it.
AR2728 looks to be developing nicely. One rather sizeable spot along with some smaller ones are easily visible, with material flowing between them observable in HA.
Setup:
HA: 150mm achromat, Quark Chromosphere, 35nm Baader H-Alpha, ASI174.
WL: 150mm achromat @ 120mm f/25, Baader Herschel Wedge, Baader Solar Continuum, ASI174.
Thanks for looking!
Setup:
Thanks for looking!
- Has thanked: 17853 times
- Been thanked: 16996 times
Re: 2021-06-01 - AR2827 med res (HA/WL)
WoW Jochen! Nice work!! I fall for the white light images every time!
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- JochenM
Cheers James/Dan.
Always more fun if the seeing decides to play nice
- Been thanked: 91 times
Hi, Jochen. Nice capture. Did you use the front end full size ERF for Ha image? I notice you decreased the aperture to 120mm for WL image, what about Ha?
Clear Sky & Regards
Stephen
Stephen
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely captures Jochen, liking the granulation. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- JochenM
Thanks Peter/Stephen/Nigella.
In this case, HA was done with the full 150mm aperture. I just use the 35nm Baader filter as a sort of mini ERF (placed on the nose of the diagonal). It keeps everything behind it safe/cool (for imaging at least; not sure I would fully trust it visually).AstrOdyssey wrote: ↑Tue Jun 01, 2021 4:29 pm Hi, Jochen. Nice capture. Did you use the front end full size ERF for Ha image? I notice you decreased the aperture to 120mm for WL image, what about Ha?
- Ivan
- Has thanked: 3483 times
- Been thanked: 2263 times
Jochen, great pictures. Beautiful color and tone.JochenM wrote: ↑Tue Jun 01, 2021 5:08 pm Thanks Peter/Stephen/Nigella.
When you shoot in Ha you don't use an aperture filter, just a sub-aperture filter?
Ivan
- Has thanked: 8559 times
- Been thanked: 8290 times
Excellent, Jochen. Great images.
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
Great images Jochen
Pedro Re'
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Very nice images Jochen!
I loved your WL...
Alexandros
I loved your WL...
Alexandros
Alexandros
Greece
Greece
- JochenM
Thanks Ivan/Stu/Pedro/Alexandros.
I just use the sub-aperture filter (2" Baader) as an ERF indeed.
- Ivan
- Has thanked: 9319 times
- Been thanked: 6157 times
An excellent set, Jochen. Good conditions are always the key to a successful session.
- JochenM
Another excellent set of your captures Jochen.
Thanks vm for sharing
That's a stunning set, I too orientate to the beautiful WL of the 'sperm' as James called it we are having a very hot week, surely Belgium is getting it too, we usually donate our weather to you
- JochenM
Thanks Terry/Alexandra.
Yeah, we got some of that heat here over the past few days as well. Have a tan already (or well, different shades of red ).
- Been thanked: 10489 times
Nice images Jochen!
