Finally managed to process the images from Sunday as well.
First FD image using using the Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO
Full size image
High-resolution image of departing AR2826 using an Explore Scientific AR152, Baader H-Alpha 35nm, Quark Chromosphere and ASI 174MM
Full size image
High-resolution image of prominence using an Explore Scientific AR152, Baader H-Alpha 35nm, Quark Chromosphere and ASI 174MM
Full size image
And finally a timelapse of AR2827 using an Explore Scientific AR152, Baader H-Alpha 35nm, Quark Chromosphere and ASI 174MM (click on the image to view the animation)
Arne
Sun in H-Alpha 30th of May 2021 - FD, high-res and timelapse.
- arnedanielsen
- Has thanked: 6181 times
- Been thanked: 7142 times
- AJamesB
- Has thanked: 1150 times
- Been thanked: 630 times
Re: Sun in H-Alpha 30th of May 2021 - FD, high-res and timelapse.
Great detail, love it!
asi178mm
asi294mm
2x, 3x, and 4x telecentrics
0.6x and 0.4x telecompressors
asi178mm
asi294mm
- Has thanked: 9145 times
- Been thanked: 6025 times
Well done Arne ! Agree with Peter, great animation showing the flaring.
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
I loved your animation Arne. It is fantastic!
Alexandros
Alexandros
Alexandros
Greece
Greece
- JochenM
- Has thanked: 1200 times
- Been thanked: 1619 times
Nice work, Arne.
Very clean animation as well.
- Has thanked: 17672 times
- Been thanked: 8792 times
Wow! terrific animation as there is so much going on all over the place
Great shots too
Great shots too
- arnedanielsen
Thank you very much for your kind words everyone!
Arne
Arne
