Sun from 30/5 taken with my Lunt50THa SS.
Bought a new camera because i had a problem with newtonrings with my ZWO 178MM. Got my eyes on the "Player One Neptune-M". It also got the IMX178 sensor but also have built in tiltadaptor. And built in memory for higher speed. So i thought i should try it out. And it is really great. The rings is gone and that makes my work in Photoshop alot easier. I also lernd that i could use Pixinsight to sharpen the picture with better resoults than PS.
For a little Lunt50 i think this is a quite good full disk.
Now i have to figure out how to get closeups. Use a powermate? Bye a Quark and use my Esprit80 or TS115mm... Are tinking that the Lunt50 works for full disks but i need something bigger for closeups but dont have the money for a Lunt 152
New camera for my Lunt50
- Ivan
- Has thanked: 3489 times
- Been thanked: 2267 times
Re: New camera for my Lunt50
Great result. I also shoot with Lunt50. Is it a mosaic or does the sun fit entirely onto your sensor?
Ivan
Ivan
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Great capture Ivan, well done with the new camera too. Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 39 times
The sun fits on the sensor. The IMX178 as a 8,92mm diagonal and the sun from the Lunt 50 is about 3,5mm i think so it's lots of space
This picture shows the sun on the full sensor
- sun 1mx178.JPG (86.81 KiB) Viewed 346 times
Lunt LS60MT/B600PT SS. Neptune-M (IMX178), Apollo-M Mini
- Ivan
Thank you, there is really a lot of space.
I see that the right side of the disc is "lit up", perhaps you already know what this happens when the pressure tuner is not tuned.
Ivan
Ivan
- Been thanked: 8907 times
That's a beautiful disc, lots of detail and the processing is superb
Yes,it's a littlebit tricky to get the sun tuned and evenly lit..
This was only to show how big the sun is on the IMX178 with the Lunt 50 The only picture i found with the full frame. Always using 1800x1800pix when i do full disk.
