June 3, 2021 AR12827 and AR12829 WL,Ha
Hi All,
It was a challenging session today imaging through thin clouds. Rather long exposure times and variable brightness during captures but the results seemed worthy of posting. There was quite a bit to see with numerous small regions of activity. I concentrated on the two major ones.
Taken with the 6” Mak, Solar Spectrum, Grasshopper GX.
- Been thanked: 5016 times
Re: June 3, 2021 AR12827 and AR12829 WL,Ha
Phil:
Very good results even with the challenging seeing.
Looks like we have the same weather and yes, it is very difficult to record with seeing like that.
- Has thanked: 17960 times
- Been thanked: 17105 times
Nice images! I especially love the first one in white light.
Beautiful setup location!!
- Has thanked: 8588 times
- Been thanked: 8324 times
Another cracking set of images, Phil, in challenging conditions. Nicely done.
- Has thanked: 20948 times
- Been thanked: 10588 times
Sublime images Phil! Can you describe how you post process the Ha images? I love the contrast you get...
- Has thanked: 9387 times
- Been thanked: 6199 times
You de master, Phil ! Love all the images and the shot of your telescope among the palms… where again are you in Florida ?
- Has thanked: 18105 times
- Been thanked: 8941 times
Thank you so much for the kind comments.
Mark, the post processing is nothing special. I capture with an old program called Astro IIDC with the gamma set to boost the contrast, the resulting .mov files are converted into .avi and stacked in AutoStakkert, imppg, then PhotoLine for a descreening, curves, levels, and denoise if needed.
Franco, I’m in St. Petersburg.
Alexandra, I’m sure you will.
Excellent images, as always, Phil.
Absolutely nice place and set-up!
Hope your next step in the solar Ha will be something like C11 with a double stack (SS + LS50FHa). Then we will see solar miracles here so frequently and so detailed as never before.
- arnedanielsen
- Has thanked: 6353 times
- Been thanked: 7411 times
Fantastic images and what a lovely location to image from Phil!
Arne
Arne
Thanks, Valery, Peter, and Arne. That location is my favorite and works for about three months of the year, the rest of the time trees block the view. I often contemplate getting a larger scope, maybe someday I will. Thanks again for the encouragement.
