4.06.2021 Massive double flare near AR12827 at 17.46[CET]
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
I was late afternoon capturing when I spotted a pair of very bright, arched flares NE of AR12827 at 17.46[CET] 4.06.2021
The flares didn't last long and reduced to bright, white streams within a few minutes.
I have lots of captures around the time but these are the images I quickly processed.
- DJD
- Has thanked: 42 times
- Been thanked: 133 times
Re: 4.06.2021 Massive double flare near AR12827 at 17.46[CET]
Excellent. Do you have enough for an animation ? I hope so.
David
David
- Has thanked: 17853 times
- Been thanked: 16996 times
WoW. I didn't catch this.
- Rusted
Hello David,
Thanks.
I have loads of captures at short intervals over a couple of hours.
It is so rarely I get transparent seeing I just kept at it.[Before and after.]
Albeit they are thermally wobbly on the monitor.
Sadly I have yet to master animations.
I can batch process in Autostakkert and ImPPG.
ImPPG alignment is still defying me.
Beyond that point I am now trying to get PIPP to cooperate.
- Rusted
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
An impressive capture!
From viewing the video, I get the impression your seeing is quite reasonable.
Peter
Peter
Excellent captures Chris.
Thanks for sharing
Thanks for sharing
- Has thanked: 9319 times
- Been thanked: 6157 times
A beautiful set of images showing the flaring, Rusted.
Thank you for the views.
- Rusted
Thank you.
The transparency of the seeing has been quite reasonable if a little unsteady.
- Been thanked: 10489 times
Good captures Chris!
- Rusted
Thank you all for your encouragement.
I have lots of videos batch processed in Autostakkert and ImPPG into .TIFF files to make an animation.
After hours and hours of trying, PIPP still refuses to make me an animated video.
Nothing I try will show more than one frame. Despite PIPP telling me I have 23 frames in an AVI.
I marked several processed stills with time stamps in PhotoFiltre and keep seeing the same label after PIPP.
PIPP just keeps adding more and more copies. Making the single image videos longer without doing anything else.
The processed .TIFFS are very closely matching and were pretty well centered during capture.
Is there something PIPP doesn't like? Image size? File type? Some inexplicable variation?
I've watched lots of YT PIPP guides where even beginners made it look easy.
I've tried GIF animation in PIPP and that just produced a still image.
- Has thanked: 2 times
- Been thanked: 347 times
Congratulations on the beautiful flare
Have you tried following Stuart's tutorial in the reference library?
viewtopic.php?f=7&t=28572
