Session time is 15:49 to 17:11 UTC. Very intermittent due to a mostly cloudy sky. The seeing is below average. The temperature is 81F.
Coronado SolarMax II 90 DS. 32x and 44.5x ( Ha )
I can easily see 5 AR plage areas on the solar disc today. AR12827 is now located in the far NW and will be gone soon. This AR shows a radiation pattern of filaments and spicules around the plage. A spot can be seen too. I can also see another small bright plage NE of it. AR12829 in the SE is easy. I can see two filaments emanating from the plage structure. I can also see a smattering of small filaments SE of it. AR12828 in the SW is certainly easier than it was yesterday being much brighter. A small plage lies to it's SW near the limb. I can also see a disturbance in the field of mottles in the NE.
Outside of the aforementioned filaments I can see two thin ones in the NNW and a thin one near the SW limb.
In doublestack I can see three prominences. A small bright one on the NE limb and another one on the NW limb. I also see one on the SW limb.
The mottles are visible across the solar disc today.
Celestron NexStar 102GT w/Altair wedge and 540nm filter. 55x ( WL )
I can see only three spots in AR12827. The large NE spot still sports a nice penumbra surrounding it's darker umbra. The faculae to the system is faintly visible. I can see a single pore in the system NE of it. SDO HMIc shows two. I can count 7 spots in AR12829 in the SE. SDO HMIc shows 10+ spots/pores. The largest spot is in the NW side of the group. AR12828 in the SW surprisingly shows two pores and a new system SW of it nearing the limb shows two pores in a fairly long bright patch of faculae. SDOHMIc shows 4 pores there!
I can see a large low contrast scattered patch of faculae in the NE but I see no spots or pores within it.
I can see the fine granulation but not that well and even then more towards the disc center.
Carpe Noctem!
I also ordered a Sky-Watcher AZGTI mount for my smaller scopes. It should work on my Coronado 60, Orion70 and Astro-Tech AT72EDII refractors. It has GoTo capability and will track Solar, Lunar and Sidereal.
At a later date I'll get a larger tracking mount for the Coronado 90 and Celestron 102. Maybe a Celestron AVX. I also plan on getting a Lunt CaK module for the Astro-Tech AT72EDII.
June 5 2021 Observations.
- Has thanked: 17572 times
- Been thanked: 16693 times
- Been thanked: 4904 times
Re: June 5 2021 Observations.
James:
Your report helped me today because it was clouded, but suddenly it cleared but with running clouds, so got to the roof observatory and started recording, had moments with very good seeing.
I am glad I could help you Eric. I await your images. Over the last week my weather has degraded a lot. Many more clouds and worse seeing. The upcoming week looks even worse.
We support each other here. Some of us get sessions in while others are clouded out. It's a fairly rare thing when nobody gets a session in on a given day. And if that happens we always have the GONG network and SDO to fall back on.
So as a solar community we can cover the Sun 24/7 !
Blessings,
Blessings,
Thanks James for the report.
In a moment some new surface-detail will be shown via SDO, so its' all happening to keep us busy...
I was hoping for a very early capture or two, but clouds are gonna interfere...
I hope clouds allow me a peek at the Sun tomorrow. Right now it doesn't look good. Thanks for the heads up via the SDO.
Goodnight Terry.
Goodnight Terry.
- Has thanked: 20424 times
- Been thanked: 10243 times
Nice report James! I'm having a day seeing if I can get caught up on all my images from the past week.
- Has thanked: 17667 times
- Been thanked: 8788 times
That's a great report James, interestingly when I was scanning the Sun with the C11 I came across 2 pores which weren't with the usual 2 main groups. I had absolutely no idea where I was on the Sun because I get so confused. At least I know I wasn't seeing things then
Nope, they are legit, Alexandra.
