Hi:
The day started with rain, then running clouds with some clear spots, so took a series of images.
Curiously had spells of very good seeing at the home observatory, did not last long then clouded all over and kept raining.
Here are some reduced shots, thanks for looking.
Have a nice Sunday.
Sol from the 5th of June 2021.
- Been thanked: 4971 times
Re: Sol from the 5th of June 2021.
Cracking set of images Eric, showing such fine detail.
I'm awaiting a small chance of getting some very early captures, but as usual the cloud is seen on satellite & radar and outside now shows the cloud to be an interference...
Thanks vm for sharing
Regards
Regards
- Has thanked: 17835 times
- Been thanked: 16976 times
Stunningly sharp Eric! Superb contrast! Your seeing was certainly good today.
Thanks for sharing these with us.
- Has thanked: 20779 times
- Been thanked: 10462 times
These look good Eric!
- Has thanked: 17970 times
- Been thanked: 8904 times
Sounds like you are getting some very British weather Eric, I feel very sorry for you and hope the weather improves.
The close ups are just heaven
- Has thanked: 6296 times
- Been thanked: 7305 times
You made good use of the clear spots between the clouds. A wonderful series with an impressive amount of sharpness in the high-res images.
Arne
Arne
Alexandra, Terry, James, Mark and Arne, thanks for the feedback.
Best regards and a good starting week.
- Has thanked: 1277 times
- Been thanked: 1070 times
Great all FD's and closeups, Eric!
As to my humble experience in hi-res imaging, there are good to catch between the clouds some frozen seeing moments, both with moderate wind and laminar air flow, or without it when clouds prevent from turbulent air heating.
So wish your great seeing and lucky hi-res images with your new coming big D-ERF!
regards
Leo
regards
Leo
