Sun in Lunt50
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Sun in Lunt50
Post by Ivan »
Hello everyone,
Again, I'm a little late)) but a lot of work, and of course these days there is not a cloud in the sky.
Full disc from June 4th. There is nothing I can do about the unevenness of the pieces of the mosaic, no matter how hard I try, Fotomerge cannot bring the picture to a uniform tone.
I would still like to hear your comments and advice.
Happy viewing,
Ivan
FD_color 04.06.21.jpg (867.96 KiB) Viewed 405 times
FD_gray 04.06.21.jpg (509.6 KiB) Viewed 405 times
FD prom_gray 04.06.21.jpg (631.41 KiB) Viewed 405 times
FD_inv 04.06.21.jpg (509.36 KiB) Viewed 405 times
Has thanked: 20738 times
Been thanked: 10430 times
Re: Sun in Lunt50
Good looking disks Ivan!
Has thanked: 17894 times
Been thanked: 8887 times
Re: Sun in Lunt50
Fabulous full discs :bow :hamster: I would hardly say you were late, I haven't done my processing from the 30th May yet :lol:
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: Sun in Lunt50
Post by EGRAY_OBSERVATORY »
Excellent captures Ivan and I would say there is anything really wrong to worry about.
Could even be a little/thin cloud causing the unevenness...
Thanks for sharing
Has thanked: 8523 times
Been thanked: 8252 times
Re: Sun in Lunt50
Post by Carbon60 »
Nicely done, Ivan.
I struggle with the same issue on FD mosaics. It’s so difficult to get every pane perfectly even.
Ivan
Re: Sun in Lunt50
Post by Ivan »
Mark, Alexandra, Terry, Stu thank you very much for your comments.
Ivan
Has thanked: 17807 times
Been thanked: 16942 times
Re: Sun in Lunt50
Post by DeepSolar64 »
Nice work Ivan. I love the last limb image!
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Re: Sun in Lunt50
Post by H-Alpha »
Beautiful full disks Ivan!
Don't worry about the unevenness. Your FDs are very well made!
In case it may be of any help, when I tried my first FD, I worked it out by selecting roughly the uneven area by hand in Photoshop and then 'Select'-->Modify-->Feather-->Image-->Adjustments-->Level or Shadows and Highlights. The feather tool is all the magic!
Hope it helps.
Alexandros
Alexandros
Greece
Re: Sun in Lunt50
H-Alpha wrote: Mon Jun 07, 2021 12:37 am Beautiful full disks Ivan!
Hope it helps.
Alexandros
I wonder if GIMP has an equivalent?
H-Alpha
Re: Sun in Lunt50
Post by H-Alpha »
DeepSolar64 wrote: Mon Jun 07, 2021 12:52 am
H-Alpha wrote: Mon Jun 07, 2021 12:37 am In case it may be of any help, when I tried my first FD, I worked it out by selecting roughly the uneven area by hand in Photoshop and then 'Select'-->Modify-->Feather-->Image-->Adjustments-->Level or Shadows and Highlights. The feather tool is all the magic!
Hi James! Good question.
I just opened GIMP and saw that under Select menu there is 'Feather...'. I suppose it is the same as in Photoshop, but have not used it yet. All the other actions I mentioned are available in GIMP. :-)
Alexandros
Alexandros
Greece
Re: Sun in Lunt50
H-Alpha wrote: Mon Jun 07, 2021 1:24 am
Alexandros
Though probably behind Photoshop somewhat in capability GIMP I feel comes in a close 2nd. And it's free of cost!
Thanks Alexandros.
Ivan
Re: Sun in Lunt50
Post by Ivan »
DeepSolar64 wrote: Sun Jun 06, 2021 11:11 pm Nice work Ivan. I love the last limb image!
Thanks, James
I collected the last picture manually. Photoshop has always refused (at least for me) to collect a mosaic from proms.
Ivan
Ivan
Re: Sun in Lunt50
Post by Ivan »
Hope it helps.
Alexandros
Thanks, Alexandros
I usually use the curves tool, but in the case of a mosaic, I cannot bring all the pieces to the same brightness level, although this should not be difficult. If initially everything is fine at first, then in ImPPG everything will appear again.
Ivan
Has thanked: 9280 times
Been thanked: 6125 times
Re: Sun in Lunt50
Post by ffellah »
Beautiful FDs Ivan
