I observed on two short occasions during small breaks through a pretty much overcast cloud cover. The first look was at around 16:45 UT and the second about 18:20 UT. I had the scope set up at the ready on the back deck while I was on the other side of the house pressure washing the siding. Naturally I had to move the scope when I reached that side of the house! Solar observers must learn how to multitask! The temperature was 79 at the first view and 81 at the second. Seeing was surprisingly decent!
I can see three spot-bearing active regions on the Sun today. AR12827 in the NW is nearing the limb but still shows it's well formed spot being trailed by bright faculae. I can see another patch of bright faculae just to it's north. SDO HMI sees a single pore there but I didn't notice it. I can also see another fainter patch of faculae NE of AR12827. AR12829 is visible as a group of 8 spots/pores with the largest being in the western part of the group. I can see no faculae since this system is at/near the CLM in the southern hemisphere and far from the limb. AR12828 is seen as a six-spot group in the far SE nearing the limb. Two are larger spots, one double and the other three are small pores. All are surrounded by faculae. I can also see a long patch of faculae to their SW very near the limb. SDO shows a tiny patch of faculae emerging from the NE limb but try as I might I just can't see it.
The fine solar granulation is fairly easy today.
Carpe Noctem!
June 6 2021 Observations. WL only.
- Has thanked: 17853 times
- Been thanked: 16996 times
Re: June 6 2021 Observations. WL only.
Glad to hear you are keeping the other half happy in between sessions I thought it was only us in the UK who had to pressure wash around the house and garden to remove all the green slime from everything after a winter.
Nah, I have to do pressure wash every summer and clean out the gutters too.
- Been thanked: 10489 times
Nice report James! There was sunshine during the day here (when I was at work), now it's home time its cloudy...
Well James and Alexandra, you are not the only ones to need the pressure-washer treatment, cus that is just to be another task around here too.
Just repainted the observatory walls, with the PT paving next.
Thanks James for your excellence.
- Ivan
- Has thanked: 3483 times
- Been thanked: 2263 times
marktownley wrote: ↑Mon Jun 07, 2021 6:36 pm Nice report James! There was sunshine during the day here (when I was at work), now it's home time its cloudy...
Lately I have had my share of clouds too. I think I'll be fighting them all week :-(
