Hi All, At last some descent whether, this is my best go so fare, I am using a Lunt 60mm h-alpha single stack. zwo asi 178mm camera, programmes imppg, Photoshop, autostakkert3, sharpcap 3.2,
peter
SUN 9/6/2021
- Dave Smith
- Has thanked: 203 times
- Been thanked: 335 times
Re: SUN 9/6/2021
Excellent
Dave
Dave
Solar kit: LUNT LS80MT B1800 FT DS Solar telescope, Rowan tilt adapter and ZWO ASI 178MM camera.
For white light, William Optics Megrez 90 and Lunt Herschel wedge. Software: FireCapture, AS!4, Imppg, Affinity Photo.
Images on the web https://www.astrobin.com/users/dwgsmith
Re: SUN 9/6/2021
Well Peter, you are now achieving some excellent results and just to combine the prom and disk images shows this very well.
Well done
Well done
- Been thanked: 4980 times
- p1taylor
- Been thanked: 219 times
Re: SUN 9/6/2021
Hi thanks all for your comments, Alexandra is there a way to get beater focus.
peter
peter
Re: SUN 9/6/2021
If your laptop-screen is used for accurate focusing, then really that is the only camera to pc method, but if you can use M.S.Windows "Magnifier" tool,
you can certainly getter a better look at the Sun's limb and then adjust the focus accordingly.
To find the screen "Magnifier" tool, go to the "START" button, then "Search" and type "Screen Magnifier"... Eventually you should find a magnifying-glass tool - appear somewhere on the screen, which gives various options to maximise/minimise etc..
Also of course having the screen as close as is practical to the scope will also make life easier...
Your combined-disk and proms are just about in focus anyway... Just very slightly over-exposed for the disk and/or a little PT tuning-adjust...
- JochenM
- Been thanked: 1619 times
