Sun FD in H-Alpha 9th of June 2021 with huge prom on the NW limb.
arnedanielsen
Has thanked: 6276 times
Been thanked: 7290 times
Post by arnedanielsen »
Dear all,
I got very lucky today when went outside to do a quick FD session with the Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO setup. I immediately noticed a huge prom on the NW-limb. It turned out that the departing AR2831 had erupted just minutes before!
Here's a short animation of the explosion from the GONG-network:
And here's my first capture about 10 minutes after the explosion.
Sun90FD_120954_Ha_(Coronado_90mm_BF15)_20210609_ZWO ASI1600MM Pro_lapl4_ap6097_Sharpened_Contrast_resize.jpg
Sun90FD_120954_Ha_(Coronado_90mm_BF15)_20210609_ZWO ASI1600MM Pro_lapl4_ap6097_Sharpened_Contrast_resize.jpg (449.05 KiB) Viewed 325 times
Full size image
Inversed and processed to better show the prominence.
Sun90FD_120954_Ha_(Coronado_90mm_BF15)_20210609_ZWO ASI1600MM Pro_lapl4_ap6097_Sharpened_Contrast_Inverted_resize.jpg
Sun90FD_120954_Ha_(Coronado_90mm_BF15)_20210609_ZWO ASI1600MM Pro_lapl4_ap6097_Sharpened_Contrast_Inverted_resize.jpg (130.42 KiB) Viewed 325 times
I took some more exposure (including a timelapse that I haven't had the time to process yet), but the prominence faded quite rapidly.
Arne
Arne
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Re: Sun FD in H-Alpha 9th of June 2021 with huge prom on the NW limb.
Post by dhkaiser »
Wow, way cool!
Dan
South central Indiana
USA
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Well done Arne on spotting and capturing your fab image
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Post by H-Alpha »
Fantastic Arne!
Thanks a lot for your post.
I suppose there is no way to predict when so violent phenomena are about to happen. Isn't it?
We just need luck?
Alexandros
Alexandros
Greece
Been thanked: 4957 times
Post by eroel »
Arne:
Beautiful result, you got the big protuberance.
Has thanked: 17807 times
Been thanked: 16944 times
Post by DeepSolar64 »
I got an alert on this through my SpaceWeatherLive app this morning just over two hours before I got up. It was a C Class flare that set this eruptive prominence off that was associated with AR12831 or AR12827 just over the NW limb.
Your timing was excellent and nice captures. GONG Udaipur shows it very well too!
Has thanked: 17905 times
Been thanked: 8888 times
WOW!!!! amazing captures :hamster: :bow ;bow this is the best eruption we have seen this cycle so far and you had the luck to capture it :hamster:
arnedanielsen
Thank you very much Dan, Terry, Alexandros, Eric, James and Alexandra for your kind comments!
I was really impressed with how fast the eruption changed/moved.
Arne
Arne
