My ten seconds of eclipse
- Has thanked: 286 times
- Been thanked: 399 times
Hi all
Despite a good weather forecast I was almost clouded out, Met Office got that wrong
I did get several views through the old Zeiss in white light very pleasing, I am trapped in now due to house building since I built my observatory sixteen years ago so to see any sort of solar eclipse from the observatory is something special
I must have got about two minuets of visible eclipse through moving thin clouds out of the whole two hours but I captured several ten second videos of which Autostakket could only stack one due to the moving cloud, I am pleased though as for the last week the weather forecast was for heavy cloud.
This was taken through the Daystar SS60-DS with a ZWO ASI174MM, piggy baked in the Zeiss, the Daystar was stopped down to 30mm giving me a focal ratio of f32.6, this gives the best image with the Quark unit.
Stacked in Autostakket, Sharpened in ImPPG, and contrast/colour added in Ps6.
The best I could get then had to carry on to work before processing.
Hope you like Rod.
Hope you like Rod.
- Eclipse 10-6-2021 10-36am Rod Tippett.jpg (791.28 KiB) Viewed 496 times
Re: My ten seconds of eclipse
Well done!!!! that is a real beauty
I was praying for one blue hole but it never came, what luck you had
- Has thanked: 17853 times
- Been thanked: 16996 times
Beautiful!!
- Has thanked: 8559 times
- Been thanked: 8290 times
Nicely done, Rod.
- Been thanked: 4427 times
Very nice shot Rod
- JochenM
- Been thanked: 1619 times
Thanks everyone nice to get some feedback.
If it wasn't for the eclipse I would never have found the little Daystar SS60-DS could do full disk images that were any good.
I actually spent some time with it over the past week or so trying different configurations until I got some good images, so that has been a result and worth doing.
Main thing was to find an area of the etalon where it was reasonably on band across the whole disk.
Also stopping down to 30mm makes a massive difference, don't know why daystar stuck a 60mm f4 lens on this thing.
Normally I just use the quark part on other scopes for high res work.
Cheers Rod
Cheers Rod
- pedro
- Has thanked: 14 times
- Been thanked: 6691 times
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
Superb!
- Ivan
- Has thanked: 3483 times
- Been thanked: 2263 times
- DanielBrousseau
- Been thanked: 138 times
Like it, kind of shot I'd liked to take .
Phantom 140 f/6.5, SW newton 254mm f/5, Quark Chromosphere, Lunt 60mm Universal, Baader ceramic wedge, ASI174 mono, ASI294 mono, ASI290 mono,
Sherbrooke, Québec, Canada
Thanks Pedro, Rusted, Ivan, Phil and Daniel
I did a little more sharpening, always wary of going to far to start with, easy to make it look dramatic but unreal and add sharpening artefacts, I think this is better though.
I still prefer the B&W one though I seem to be able to see more detail.
Rod
Rod
- Eclipse 10-6-2021 10-36am Rod Tippett Sharp S.jpg (511.53 KiB) Viewed 389 times
- Eclipse B&W 10-6-2021 10-36 Rod Tippett.jpg (226.53 KiB) Viewed 389 times
