Today's SUN (20210611) H-alpha FDs + Video
pedro
Has thanked: 14 times
Been thanked: 6686 times
Post by pedro »
WEB LINK:
http://pedroreastrophotography.com/sun_ ... 21-06.html
Solar imaging session (20210611) | Pedro RE'
TV101, LUNT60 (H-alpha)
GS3-U3-28S4M, Takahashi EM-400
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
SUN (20210611) H-alpha (12:00 UTC). TV101 F/5.4, DS SM90II/SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210611) H-alpha (12:00 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210611) H-alpha (12:00 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Re: Today's SUN (20210611) H-alpha FDs + Video
Post by Ivan »
You surprise every time. An excellent and illustrative comparison. How do you deal with dust?
Ivan
pedro
Post by pedro »
Thanks again Ivan
I usually do not use any flats. A good cleaning of the ccd/cmos window is a must
It helps to keep the cameras in a sealed case (eg pelican)
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Excellent presentation Pedro.
Yes indeed, keeping those "Dust Bunnies" away in the first place is a must, so any open optics/cameras must be immediately-capped, or as Pedro correctly uses the sealed-case method.
My three scopes and cameras are left in situ and just the objectives are covered when finished with and when that is done, a fairly powerful blower-pump is used to blow dust away from the tri-scope assembly and mount etc., before covering the whole set-up with an appropriate water-proof/dust sheet, ready for an immediate restart at the next session... Never really had any "DB" issues in up-to 10-years - that way.
A little work, can save a lot of work...
Thanks Pedro
Has thanked: 17925 times
Been thanked: 8894 times
These are an amazing trio of discs Pedro, the large prom is the star of the show I think :bow :hamster:
Has thanked: 8523 times
Been thanked: 8258 times
Post by Carbon60 »
Great shots, as always, Pedro.
Has thanked: 17813 times
Been thanked: 16953 times
Post by DeepSolar64 »
Very nice work Pedro. I missed that nice prom due to clouds. I barely got a WL observation in. The 12th was even worse, it was cloudy almost the whole day with thunderstorms and rain. I barely got a peek at the Sun with my Lunt 8x32 SUNoculars. Nothing there was large enough or high contrast enough to see in such a small white light instrument. The GONG white light intensitygram did show a new spot very near the NE limb.
Good luck on a Sunday session.
pedro
Post by pedro »
Thanks again guys
