AR2829 with Prom & AR2832, HA & CaK | June 11th 2021
MalVeauX
Has thanked: 1182 times
Been thanked: 1373 times
Post by MalVeauX »
Heya,
Been a nasty few days of weather, had small holes between the clouds this morning but seeing was pretty good, so I was able to grab quick data. There's a great prominence near AR2829 as it all rounds the limb, great active area. AR2832 has some nice plage and mottling with a filament near by. Overall low activity. I missed that great eruption due to work (and weather was bad anyways). And of course I'm not in the pathway of the partial eclipse from the other day. Alas! There is good news though, if you read on SpaceWeather a little article about the Terminator Event (let's hope its true!).
B&W:
Colored:
Seeing:
Lots of clouds, had to image as a cloud left and into one entering FOV, but the seeing between the clouds was decent.
Equipment:
Celestron Omni XLT 120 (Synta); Air-gap of 1.94mm between the lenses; masked to 100mm F10
Lunt CaK B1200 Module + 1.62x amplifier (F16.2) + ASI290MM (Moderate resolution CaK at 0.37"/pixel)
Celestron Omni XLT 120 (Synta); Air-gap of 1.94mm between the lenses; masked to 60mm F16.7
Lunt CaK B1200 Module + IMX253 sensor (CaK full disc)
Baader Blue CCD-IR Block Filter + Baader ND 3.0 Filter + GSO Polarizer Filter + Altair Astro 395nm 7nm Filter + IMX253 sensor (Near UV Disc)
C6R (Synta); masked to 120mm F10
Baader Red CCD-IR Block Filter (internal sub-aperture D-ERF)
PST Etalon + 10mm BF + ASI290MM (Moderate resolution HA at 0.5"/pixel)
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: AR2829 with Prom & AR2832, HA & CaK | June 11th 2021
Post by EGRAY_OBSERVATORY »
All your captures are absolutely excellent Marty and thanks for the presentation
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Beautiful results, Marty, particularly the closeups.
Peter
Has thanked: 17925 times
Been thanked: 8894 times
These are gorgeous Marty :bow :hamster: I'm also hoping for this paper to be correct too :hamster:
Astrophil
Been thanked: 581 times
Post by Astrophil »
Great looking images, Marty. Glad we got a little sun in the sunshine state.
Phil
