Hi all,
I have been sent the following and found it beautiful enough to share with you! :-)
Do you think that 50000 frames were the total captured? And then this could be 100 captures of 500 frames? How would you have made such a video?
https://petapixel.com/2021/06/11/this-2 ... 00-photos/
Enjoy!
All the best,
Alexandros
Beautiful solar eclipse time lapse
- H-Alpha
- Has thanked: 1675 times
- Been thanked: 982 times
Alexandros
Greece
Greece
- Has thanked: 8685 times
- Been thanked: 8420 times
Re: Beautiful solar eclipse time lapse
Nice one, Alexandros. Thanks for sharing.
100 captures of 500 frames is the most likely way this was done. Image stacking each set and then running as an animated Gif after aligning to ensure the final sequence is stable.
- Has thanked: 18353 times
- Been thanked: 9014 times
