June 12th - Ha (Date Corrected)
- Been thanked: 4340 times
Hi all...
My intentions to be home from work by mid morning evaporated as most busy days do, and I had almost given up on trying to image as the sun/cloud ratio was not going in my favour in the early afternoon. I did a quick look with the PST and that convinced me to try.
These images are full disk Ha through the LS80T/LS75FHa/B1800Ha and ASI174MM camera. The first is a composite of separate disk and limb images, and the second is a longer exposure to pull up the odd floating prom in the NE. I've seen a prom with this appearance before, but it certainly looks cool The seeing was poor so I put the 3x focal extender on the LS80T and got some slightly higher resolution images of the main areas of interest. The image below is a 2 frame mosaic of the eastern and northern disk. There was a large area showing activity in the SE and a new AR just starting to show in the NE. A large prom was also associated wit this new AR...now maned AR2833. The next image is centred on the western disk and shows AR2832: The image below is centred on the SW limb where there is a nice filament and some activity showing near near the limb: The final set of images are longer exposures to pull up the proms: The floater on the NE limb was hard to get with long exposures, poor seeing, and increasing cloud cover.
That covers the session from Saturday. I'm glad I went out after-all
- Has thanked: 9143 times
- Been thanked: 6024 times
Re: June 14th - Ha
A totally beautiful set, Brian. Love the proms and specially the floating prom. That was a great catch, we do not see that very often…
Re: June 14th - Ha
Thanks Franco
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: June 14th - Ha
Bravo Brian, excellent images showing all the areas of interest.
Dan
South central Indiana
USA
USA
Re: June 14th - Ha
My thanks go out to Dan and Jeff...feedback is always appreciated
Re: June 14th - Ha
Thank you Brian for your excellent captures and also the prom at the associated AR2833.
Best Wishes
Best Wishes
Re: June 14th - Ha
Thanks Terry...the feedback is always appreciated
- Has thanked: 42 times
- Been thanked: 1487 times
Re: June 14th - Ha
Those are really nice. Also great to know what the Sun will look like a day ahead of time (June 14)
Re: June 14th - Ha
Hi everyone...
Well, I seem to be predicting the future with this post...sorry about that Thanks to 'thesmiths' for pointing that out!
The images are from the 12th.
- Been thanked: 16689 times
Re: June 12th - Ha (Date Corrected)
Very nice work, Brian.
- Has thanked: 17648 times
- Been thanked: 8787 times
That's fab Brian, I love the full disc shot as the floating prom looks like a UFO hovering over the Sun
