Well after starting-work at 5AM in the observatory for the last two days, before the temperature rises to 40-degsC., I decided to open-up and with very "CLEAR SKIES" when the Sun rose enough to capture the new AR2833 in 3-lights.
Also noticed quite a few proms and a large one too, so attached are those here..
I make no apologies for the less than perfect captures, as although I have taken loads of large AVI's, I will be going through those in the cool-climate - indoors. Will post later if any better than these single-frame shots.
Enjoy and CLEAR SKIES..
AR2833 and Prominences too today Monday 14th June
- 14-6-2021 0756z WL AR2833.jpg (206.61 KiB) Viewed 325 times
- AR2833cr4.jpg (173.78 KiB) Viewed 325 times
- 14-6-2021 0742z CAK AR2833.jpg (1.43 MiB) Viewed 325 times
- 14-6-2021 0743z CAK-PROMINENCES.jpg (264.29 KiB) Viewed 325 times
- 14-6-2021 HA AR2833.jpg (825.55 KiB) Viewed 325 times
- 14-6-2021 0736z HA-PROMS.jpg (257.08 KiB) Viewed 325 times
- Has thanked: 18101 times
- Been thanked: 8935 times
Re: AR2833 and Prominences too today Monday 14th June
Superb images Terry you caught the CaK proms really well I've never managed to spot them with my Lunt module
- Has thanked: 9383 times
- Been thanked: 6199 times
Excellent work catching the new sunspot and prominences, Terry. Here only clouds and rain.
Many thanks Alexandra. You should be able to catch those CaK proms by in some cases, by simply over-clocking the the capture time from that used for surface detail to basically an 'all-white' disk and maybe beyond. Certainly the Lunt 60mm can do that (in my case)...
Thanks Franco for your welcome comments. Blue skies were all day, up to around 1300z, but now quite a lot of cloud and no doubt the beginning of something more drastic, such as thunderstorms in the next two days onwards.. (I see that is happening in N.France and to the west of - too.)..
At least the temperature here is now 30-degsC outside of the observatory and 40+ in the observatory with the roof closed or open...!!
CLEAR SKIES
CLEAR SKIES
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
We'll done Terry, great you got that big prom in CaK. I too managed that in CaK today. I actually like trying to capture those prom's in Calcium II K. Thanks for sharing. Hopefully you'll get others processed from today..
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17949 times
- Been thanked: 17095 times
Nice Terry! I am glad you got to image today.
Thank you Ella and James.
I am quite busy with other chores, so for the moment finding the time to process the many AVI's of the captures (like Ella) is not always too easy.
I also prefer to post the images on (or as near to) the same day captured, which for yesterday was not possible, so may try again today...
I've just been informed that a large prom was around early today, but I was "in the land of the nod" then, so have appeared to have missed that...
- Has thanked: 2501 times
- Been thanked: 4925 times
