AR12833 HUGE proms Animation ruined by temperature change :'(
- minhlead
- Has thanked: 739 times
- Been thanked: 1107 times
What a waste! I remote to my observatory and start capturing without realizing I forgot to turn on the temperature compensation on the Focuser. Since I was remoting from work, I have no idea the focus was off (the remote screen is blurry).
The result was disappointing despite the very good seeing this morning after a week of tropical storm . Hope you guys enjoy it, and I'd certainly remember to calibrate the temperature compensation the next clear sky I got. Be advised, the gif is BIG
Minh.
Loves from Viet Nam <3
My gear:
Mount: JTW Tridents GTR
Camera:
PlayerOne Apollo M-Max
My gear:
Camera:
- Has thanked: 9307 times
- Been thanked: 6144 times
- minhlead
Re: AR12833 HUGE proms Animation ruined by temperature change :'(
Minh.
My gear:
Camera:
My gear:
Camera:
- Been thanked: 2725 times
We can seen the solar rotation !
Too bad for the focus shift. Next time will be OK.
- minhlead
Thanks Christian. I certainly will be more careful next timechristian viladrich wrote: ↑Tue Jun 15, 2021 11:51 am We can seen the solar rotation !
Minh.
My gear:
Camera:
My gear:
Camera:
- Has thanked: 17970 times
- Been thanked: 8905 times
It starts off great and lots of activity can be seen Wow! that's something I need, being able to remote telescope from work
- minhlead
Thanks Alexandra
I made my observatory with internet remote in mind. Everything can be controlled via desktop remote. It's automated and the roof will close when it's rain/cloudy/too windy. And it's relatively cheap. I built mine for about 700$ everthing included .
Here's a video of my observatory in action.The mount waits for the object to pass a threshold altitude before start aligning, focusing, guiding and capturing all automatically. The cloud recovery now works very well as well. At the end of imaging session (dawn), the scope will park itself, warm the CCD and the ROR closes.
The whole imaging session happened without any human input, just schedule with constrains.
output2 by Nguyen Minh, on Flickr
Minh.
My gear:
Camera:
My gear:
Camera:
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
Minh, good animation, everyone is wrong.
You perform technical miracles. I think many will be interested to know about the construction of your observatory. By the way, you wanted to collect SSM, did you succeed?
Ivan
Ivan
- minhlead
Thanks Ivan,
It's not that hard actually. A lot of the tools are well written and documented online. You just need basic coding and engineering skills. I am not a coder by proffession just very basic knowledge.
I still could not find the time to make the SSM. The guide seems straight forward enough, I think I will get into making one in a week or 2
Minh.
My gear:
Camera:
My gear:
Camera:
- Ivan
minhlead wrote: ↑Tue Jun 15, 2021 6:01 pmThanks Ivan,
Minh, thanks, I'll look forward to it, just hope to repeat it later.
Ivan
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Minh this is amazing what you have succeeded in building your remotely operated observatory!!!!
I did not even know that there is a possibility to compensate for temp change with the focuser! What focuser do you have?
Thanks for sharing all this!
Only thanks to Christian's comment, I saw the sun rotation! Amazing! For how long where you capturing?
Alexandros
Alexandros
Alexandros
Greece
Greece
- Has thanked: 17845 times
- Been thanked: 16977 times
It still looks good.
- minhlead
Thanks James, Maurits, Alex.
@Alex: the optical path expands linearly with temperature change so it's quite easy to do calibration of a temperature based focus shift. (I.e: if temperature change by x degree then the focus move in/out by y steps). I use it all the time with my DSO capture software. You have to do a calibration for each optical rig though, since the shift constant is different from scope to scope. Observe the change in focus absolute step from observing temperature in a few time and divide them by the temperature change in degree, you'd have that constant. Some hi-end focuser have this feature hard coded to the firmware, you just have to put the constant in and it will compensate for the focus shift with onboard thermometer.
Mine (ZWO EAF) does not have this. It has to relied on the controlling software for this. And Sharpcap, AFAIK does not support this. Will have to find a way to overcome this. Maybe I'll write a little program piggyback on the ascom and compensate the shift independently, not supposed to be hard.
I am suspecting the focus shift effect is more severe with this case because of the large Delta T (+15*C) from start to end of the imaging session and the 4.3x barlow of the Quark magnifing the focus shift by 4.3 times so it's more pronounced. I have never had it this bad while doing DSO.
Minh.
My gear:
Camera:
My gear:
Camera:
- H-Alpha
Thanks Minh. Really impressive what you are doing and your ideas for improvement and automation as well!
What was the duration of your total capture to have the rotating sun in this animation?
Alexandros
Alexandros
Alexandros
Greece
Greece
- banjo
- Has thanked: 2100 times
- Been thanked: 2876 times
- cmas
- Has thanked: 294 times
- Been thanked: 248 times
This animation is still very nice even though you missed the focus. The action looks wonderful! I do really like your remote setup, too. That's the way to go if it is possible (for me its not possible). Keep up the good work!
Images in AstroBin
Images in Flickr
Images in AstroBin
Images in Flickr
- minhlead
This is 3 hours of capturing. The key thing to get the sun rotation is aligning the frames by solar limb (using ImPPG) if you aligning using surface features (like most Fourier aligning algorithm does) the spot would be fixed and you wont see the rolling effect.
Minh.
My gear:
Camera:
My gear:
Camera:
