good evening to all,
last week, I look by curiosity the site "transit finder" and I discover that the ISS passes in front of the sun on June 13 at 10:05 UT visible .... from my home !
So, big blue sky, no need to move, I made the effort to try it!
at the fs60 with its sm40 double stack, BF10, glasspath x1.7 and zwo178mm
camera setting :
FPS (avg.)=41
Shutter=2.125ms
Gain=100
Gamma=40
film (slow motion x4) of transit reduced to 50%.
two things are noticeable: the "transit train" is not regular and the ISS even makes a retrograde movement .... which (unless Thomas wanted to turn around to take my picture ) is not quite normal.
I suspect that the rolling shutter of my camera is responsible for this.
Well, I did get an image from the film anyway
Sincerely
stéphane
transit of the ISS in front of the sun in halpha on 13 June
- stef41
- Has thanked: 124 times
- Been thanked: 1488 times
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Re: transit of the ISS in front of the sun in halpha on 13 June
Excellent capture of the ISS Stephane!
How did you manage to get a so small in size gif out of the original capture? What was your process? Did you select/extract specific frames from the video one by one and then made the gif out of them?
And how did you make the photo? Just stacking the video capture gives back all the ISS positions on the sun?
Alexandros
Alexandros
Alexandros
Greece
Greece
- Has thanked: 17970 times
- Been thanked: 8902 times
Absolutely fantastic!!! every transit of the ISS I consider a miracle
- banjo
- Has thanked: 2100 times
- Been thanked: 2876 times
bravo !!!! Steph
- stef41
thanks to you
selected just the frames containing the ISS and extracted it as an AVI
I opened the AVI in virtualdub, resized it to 50%, cropped it and set it to 10fps ; and, finally, exported it as a GIF
and also save as XVID, even smaller than GIF (1.3Mo)
http://www.astrosurf.com/ls35dx/new53/S ... mm-r50.avi
Then I extracted the frames from the previous AVI with PIPP and put these frames on my previous image with layers in "darken" mode (see tuto: https://www.thelondonastronomer.com/it- ... ce-station )
Sincerely
stéphane
I opened my original ser (2000 frames) in registax.
I processed my 2000 frames film normally, it gave me my image of the sun.
Sincerely
stéphane
- H-Alpha
Thank you very very much Stephane! Merci enormement!!! :-)
This helps a lot.
Now I will be ready for the next passage of ISS above my head. ;-)
Alexandros
This helps a lot.
Alexandros
Alexandros
Greece
Greece
Nice to see Stéphane and congrats on SPOD.
