15June: Hi-Res H-alpha of Proms and AR12833
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Hi Everyone.
Here are the results of a June 15 imaging session with above average seeing conditions. The C8 Edge / Daystar 0.6QPE system was used with a slight modification to my telecentric focal extender to give higher magnification (focal ratio f/60). The first AR image was taken at f/60 while the remaining shots employed focal reduction to about f/45.
Peter.
Peter.
Re: 15June: Hi-Res H-alpha of Proms and AR12833
Amazing images, Peter. Your 8" solar imaging setup delivers excellent results in both surface and prominences.
Thanks for sharing.
Thanks for sharing.
- p_zetner
Thanks Valery!
I hope to experiment with the Lunt/Daystar double stack one of these days soon.
All the best.
Peter
All the best.
Peter
- Rusted
- Has thanked: 8016 times
- Been thanked: 1938 times
These are exceptional images! With excellent detail despite the large scale. Beautifully processed too.
- Been thanked: 8792 times
Wow!! these are exceptionally beautiful Peter
- p_zetner
Thanks Chris and Alexandra!
Sometimes I think I get a bit heavy handed with the sharpening and a little too timid with the levels / contrast.
Here are reprocessed versions of the highest magnification AR images.
I'm trying to get a bit more "drama" without sacrificing detail.
Any feedback is welcome!
Peter
Peter
- JochenM
- Been thanked: 1619 times
Impressive shots, Peter.
For these highres shots, a bit more contrasty midtones definitely works for me. Looks good!
- Been thanked: 4904 times
Peter:
Super HR images, clean and crisp.
Thanks for sharing them.
- Has thanked: 1262 times
- Been thanked: 1057 times
Fabulous images, Peter!
Your setup is adjusted very well, the etalon first of all.
How many frames you stacked for both proms and AR?
regards
Leo
regards
Leo
- Has thanked: 17581 times
- Been thanked: 16696 times
Beautifully done Peter. Awesome resolution!
- p_zetner
Thanks Jochen, Eric, Leo and James!
Jochen: Thanks for your opinion. I still "waffle" back and forth between the higher and lower contrast versions.
Leo: The ARs were stacks of 50 out of 2000 while the proms were 25 out of 2000. It's a bit low in number of stacked images so they are a bit noisier than I'd like but I prefer the better detail.
Peter
Peter
- Has thanked: 9145 times
- Been thanked: 6025 times
Incredible close ups and prominences, Peter ! f/60 ? I am glad your are pushing the limits out... and succeeding.
- Has thanked: 8418 times
- Been thanked: 8164 times
Excellent, Peter. You’ve captured superb levels of detail in these images.
- Has thanked: 1640 times
- Been thanked: 878 times
