This is my view of AR2833 a wider view than I normally do by using a 0.5 reducer just before my ASI174mm after the Quark, as the seeing was bubbling away as the sun was getting close to next doors roof. I cropped out the best part of the image ROI as well to speed up the frame rate.
Ended up with this stack of 1,800 frames, nice result.
Taken with 150mm refractor working at F10 and Quark Chromo ASI174mm.
Rod
AR2833 proms and filaments
- Been thanked: 4786 times
Re: AR2833 proms and filaments
Excellent image Rod, showing the spot, filaments and proms in one...
Well done
Well done
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
- Been thanked: 16694 times
Nice! You got the filaprom.
- JochenM
- Been thanked: 1619 times
- Been thanked: 8791 times
- Has thanked: 9145 times
- Been thanked: 6025 times
