06.16.21 Sun in Lunt50
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Hello everyone,
Full disc June 16, mosaic of 6 fragments.
I would be glad to hear your assessments and recommendations.
Ivan
FD color.jpg (1 MiB) Viewed 726 times
FD gray.jpg (698.27 KiB) Viewed 726 times
FD inv proms.jpg (784.82 KiB) Viewed 726 times
FD inv.jpg (842.74 KiB) Viewed 726 times
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: 06.16.21 Sun in Lunt50
Post by EGRAY_OBSERVATORY »
These are excellent images Ivan - showing lots of detail.
Thanks for sharing
Ivan
Post by Ivan »
EGRAY_OBSERVATORY wrote: Wed Jun 16, 2021 10:05 pm These are excellent images Ivan - showing lots of detail.
Thanks for sharing
Thank you Terry, good to hear from you.
Ivan
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Post by dhkaiser »
Looks real good to me Ivan.
Dan
South central Indiana
USA
Has thanked: 17807 times
Been thanked: 16940 times
Post by DeepSolar64 »
Ivan,
That's better than any Ha disk I have ever done. Your disc is evenly illuminated, good contrast and sharpness is just right. All details are shown. The plage of AR12833 just " pops " ! I love the first colored Ha FD!!!
BIG thumbs up!!
Ivan
Post by Ivan »
dhkaiser wrote: Wed Jun 16, 2021 10:42 pm Looks real good to me Ivan.
Thanks, Dan
Ivan
Ivan
Post by Ivan »
DeepSolar64 wrote: Thu Jun 17, 2021 4:45 am Ivan,
BIG thumbs up!!
Thank you James, I'm very glad you liked it.
Sometimes I can do it evenly, but more often I don’t. I haven't figured out all the reasons yet. I think it depends on seeing, little visible clouds, etalon setting. I am sure there are many more reasons.
If it helps, then it was for this disc that I additionally filmed the central fragment. He became the basis of the mosaic. Perhaps this is why the background has become more uniform.
The mosaic I collected in Fotomerge is a function in Photoshop. Each piece of the finished mosaic can be lightened or darkened using "levels" or "curves". But I'm rarely satisfied with the result. Therefore, more often I use the "darken" or "lighten" tools with the lowest intensity settings. You can also use luma masks.
Exposure was 1 ms, shot at noon in strong winds. I shot 1000 frames, of which I added 15%.
For the experiment, I removed 3 discs with shutter speeds of 2, 3 and 1 ms, but I had not yet had time to process them.
Contrast and detail made in ImPPG. Then I darkened it in Photoshop, but it's a matter of taste.
The article that Alaxandra wrote helped me a lot: https://solarnutcase.livejournal.com/18572.html
Ivan
Has thanked: 17888 times
Been thanked: 8887 times
This is excellent Ivan :bow :hamster:
Do you use flats for each part of the mosaic? To get an even disc I take all the frames, then go to the centre of the Sun, cover the front with opaque plastic and take a flat. I then use this flat with all the pieces of mosaic, then put them together in Photomerge. I find this helps with patchiness (most of the time).
Ivan
Post by Ivan »
Montana wrote: Thu Jun 17, 2021 10:52 am This is excellent Ivan :bow :hamster:
Thank you, Alexandra
I forgot to add that at the beginning or end of the session, I make sure to shoot flats frames and add master flat in AS, and then calibrate all the fragments of the mosaic with it.
This helps to make the result uniform in brightness, but, unfortunately, not always. In my case, this is 3 or 4 successful panoramas out of 10. In other cases. I use the methods I wrote about above.
Ivan
I have used Photomerge in PhotoShop years ago. I used it to do panos by putting pictures together. I wonder if GIMP has a similar tool?
Ivan
Post by Ivan »
DeepSolar64 wrote: Thu Jun 17, 2021 1:36 pm I have used Photomerge in PhotoShop years ago. I used it to do panos by putting pictures together. I wonder if GIMP has a similar tool?
I don't know James. I heard that a panorama can be assembled in the Image Composite Editor (ICE). Someone is using this program here in the forum.
Ivan
Ivan wrote: Thu Jun 17, 2021 5:50 pm
Ivan
My guess would be Rainer.
eroel
Been thanked: 4957 times
Post by eroel »
Ivan:
Very good mosaics, I also use Photomerge or Autostitch.
Best regards.
Ivan
Post by Ivan »
eroel wrote: Thu Jun 17, 2021 6:39 pm Ivan:
Best regards.
Thanks a lot Eric.
I'm glad I liked the mosaic.
Ivan
davidem27
Has thanked: 81 times
Been thanked: 247 times
Post by davidem27 »
Really natural processing.
I love the color image.
What is the used camera?
Calcium II K: Lunt B1200
www.volpetta.com
Ivan
Post by Ivan »
davidem27 wrote: Fri Jun 18, 2021 7:19 pm Really natural processing.
Hello,
I'm glad you liked it. I used the old qhy img0s camera. This is a monochrome ccd with non-adjustable cooling. The Lunt50 lacks focuser travel, so I have to use a 2x Barlow lens.
The color is synthetic, I'm still at the stage of finding the RGB balance.
Ivan
davidem27
Post by davidem27 »
Ivan wrote: Fri Jun 18, 2021 8:46 pmThe Lunt50 lacks focuser travel, so I have to use a 2x Barlow lens.
I am experiencing the same identical issue.
Neither with the attached barlow I can reach focus.
So strange.
www.volpetta.com
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Post by p_zetner »
Beautiful disks, Ivan.
You have done a superb job of creating even illumination in these mosaics.
Peter
Ivan
Post by Ivan »
davidem27 wrote: Fri Jun 18, 2021 10:47 pm
So strange.
Are you missing a focuser inward or outward?
Ivan
Ivan
Post by Ivan »
p_zetner wrote: Fri Jun 18, 2021 11:18 pm Beautiful disks, Ivan.
Peter
Thanks, Peter.
Ivan
davidem27
Post by davidem27 »
Ivan wrote: Sat Jun 19, 2021 12:23 amAre you missing a focuser inward or outward?
If I try to use camera without barlow, I have minimal inward issues. This mean that, to reach focus, I have to change diagonal eyepiece holder with a shorter one than the original.
If I put a barlow in the optical train, I can never reach focus.
I do not have the OEM helical focuser but a 40mm non-rotating helical focuser, sturdier and smoother than the original one.
My thoughts goes to future mods of Frankenscope using its etalon module. May I have critical focus issues? Perhaps this is an argument for a different topic...
www.volpetta.com
Petrus
Has thanked: 1578 times
Been thanked: 747 times
Post by Petrus »
Fantastic images, Ivan!
~ Petrus ~
Flickr
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Fabulous full disk images, Ivan
Ivan
Post by Ivan »
ffellah wrote: Mon Jun 21, 2021 10:15 am Fabulous full disk images, Ivan
Thank you Franco
Ivan
Ivan
Post by Ivan »
davidem27 wrote: Mon Jun 21, 2021 7:51 am
Hi, I read your site, it was interesting.
Regarding focusing, unfortunately I cannot help you. I read about this problem, one solution is to replace the eyepiece holder (on the blocking filter) with a shorter one. Here's an example: https://stargazerslounge.com/topic/2510 ... d-sort-of/
But before that, I recommend just unscrewing it and bringing the camera up to make sure there is focus. By modifications, there is a whole branch here: viewforum.php?f=9
I recommend reading this material, there is just about Lunt50: viewtopic.php?f=9&t=19238 Ivan
davidem27
Post by davidem27 »
Thank so much for the appreciation and for your answer, Ivan.
I'm browsing these topics so hard and I'm trying to figure out the best solution for me.
www.volpetta.com
