Sun FD in H-Alpha and CaK 15th of June 2021
arnedanielsen
Has thanked: 6276 times
Been thanked: 7298 times
Post by arnedanielsen »
Dear all,
I'm a little behind on my image-processing, but here are some shots from June 15th.
First out FD image in H-Alpha using the Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO.
Sun90FD_154426_Ha_(Coronado_90mm_BF15)_20210615_ZWO ASI1600MM Pro_lapl4_ap6087_Sharpened_Contrast_resize.jpg
Sun90FD_154426_Ha_(Coronado_90mm_BF15)_20210615_ZWO ASI1600MM Pro_lapl4_ap6087_Sharpened_Contrast_resize.jpg (419.46 KiB) Viewed 254 times
Full size image
Sun90FD_154426_Ha_(Coronado_90mm_BF15)_20210615_ZWO ASI1600MM Pro_lapl4_ap6087_Sharpened_Contrast_Colorized_resize.jpg
Sun90FD_154426_Ha_(Coronado_90mm_BF15)_20210615_ZWO ASI1600MM Pro_lapl4_ap6087_Sharpened_Contrast_Colorized_resize.jpg (468.88 KiB) Viewed 254 times
Full size image
FD image in CaK using William Optics ZenithStar 61II stopped down to 46mm, Lunt Cak 1200 module and ASI 178mm camera.
SunCaK60_155325_CaK_(3934nm)_20210615_ZWO ASI178MM_lapl4_ap2830_Sharpened_Contrast_resize.jpg
SunCaK60_155325_CaK_(3934nm)_20210615_ZWO ASI178MM_lapl4_ap2830_Sharpened_Contrast_resize.jpg (261.54 KiB) Viewed 254 times
Full size image
SunCaK60_155325_CaK_(3934nm)_20210615_ZWO ASI178MM_lapl4_ap2830_Sharpened_Contrast_Colorized_resize.jpg
SunCaK60_155325_CaK_(3934nm)_20210615_ZWO ASI178MM_lapl4_ap2830_Sharpened_Contrast_Colorized_resize.jpg (285.85 KiB) Viewed 254 times
Full size image
SunCaK60_155325_CaK_(3934nm)_20210615_ZWO ASI178MM_lapl4_ap2830_Sharpened_ShadowHiglights_resize.jpg
SunCaK60_155325_CaK_(3934nm)_20210615_ZWO ASI178MM_lapl4_ap2830_Sharpened_ShadowHiglights_resize.jpg (307.81 KiB) Viewed 254 times
Full size image
SunCaK60_155325_CaK_(3934nm)_20210615_ZWO ASI178MM_lapl4_ap2830_Sharpened_ShadowHiglights_Colorized_resize.jpg
SunCaK60_155325_CaK_(3934nm)_20210615_ZWO ASI178MM_lapl4_ap2830_Sharpened_ShadowHiglights_Colorized_resize.jpg (346.56 KiB) Viewed 254 times
Full size image
Thanks and best regards,
Arne
Arne
AstroBin: https://www.astrobin.com/users/arnedani/
EGRAY_OBSERVATORY
Been thanked: 4900 times
Re: Sun FD in H-Alpha and CaK 15th of June 2021
Post by EGRAY_OBSERVATORY »
Fine set of images Arne and the colouring is well good too.
Thanks for sharing
Has thanked: 17925 times
Been thanked: 8894 times
Wow!! the CaK are exceptional, a lovely set of full discs :bow :hamster: I've still not processed my images from the beginning of June ;)
Has thanked: 9298 times
Been thanked: 6133 times
Post by ffellah »
Beautiful FDs, Arne.
arnedanielsen
Thank you so much for your kind comments, Terry, Alexandra and Franco.
All the best,
Arne
Arne
