18th June Quick process from this morning
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Hi all, in the midst of DIY managed to capture and do a quick process with CaK between the clouds. 100mm AR stopped down to 80mm and Zwo asi 178mm camera. Clouds didn't permit any other wavelength capture.
- 20210618-1038UTellabryant-FDCaK-col.jpeg (468.82 KiB) Viewed 506 times
- 20210618-1038UTellabryant-FDCaK.jpeg (443.68 KiB) Viewed 506 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 9143 times
- Been thanked: 6024 times
Re: 18th June Quick process from this morning
That is an excellent CaK FD Nigella, thank you for the views.
- Stardust5858
Thanks Franco, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Been thanked: 16689 times
Splendid CaK image! I so wanna do this!
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Very fine CaK discs, very sharp. Have you used any focal reducer ?
Raf
- Has thanked: 17648 times
- Been thanked: 8787 times
Dead centre!! that would make a good hi res object at the moment, pity it is all cloud here
Lovely images
Lovely images
- davidem27
- Has thanked: 81 times
- Been thanked: 247 times
Oh! You made me melt myself into your hot cak-sunlight!
I'm mad at this wavelength!
Calcium II K: Lunt B1200
www.volpetta.com
www.volpetta.com
- Stardust5858
Thanks James, appreciated. It well worth the investment James. I love calcium II K as much as HA.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Hi Raf, yes I use an 0.5 reducer as my CaK scope is F10.krakatoa1883 wrote: ↑Fri Jun 18, 2021 2:38 pm Very fine CaK discs, very sharp. Have you used any focal reducer ?
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Alexandra much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
I love this wavelength too David.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 6181 times
- Been thanked: 7142 times
Well done Ella on finding the time to produce the excellent captures.
Regards
Regards
- Stardust5858
Thanks Arne, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Terry, I used the computer in the obsy to process which is so much faster than my ancient laptop. Think I might be processing my images in future in the obsy, lol.EGRAY_OBSERVATORY wrote: ↑Fri Jun 18, 2021 4:34 pm Well done Ella on finding the time to produce the excellent captures.
Regards
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Nigella these photos are very beautiful!
Excellent contrast and details!
Alexandros
Alexandros
Alexandros
Greece
Greece
- Stardust5858
Thanks Alexandros, much appreciated.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
