This spot is still very prominent but doesn't seem to be evolving beyond the present stage. It's a nice view in white light because of the well developed penumbra and in H-alpha too as it is surrounded by several filaments. Below is an image I took with my usual setup, since I was in a hurry I completely forgot to take a flat...
Thanks for looking!
AR12833 in H-alpha
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
AR12833 in H-alpha
- 2021-06-18-1316-Halpha-AR12833.jpg (175.26 KiB) Viewed 416 times
Raf
- Has thanked: 9319 times
- Been thanked: 6157 times
Re: AR12833 in H-alpha
That is a fantastic image, Raf. I can't believe you got that in a hurry...
- krakatoa1883
Thanks Alexandra. Franco, I was really in a hurry, usually I take a flat but this time i didn't so the upper part of the image is darker than the rest....
Raf
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
Excellent capture and subtle, elegant processing.
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Very nice image as always Raf!
The filaments around the spot are quite active recently I think. Not like the end of last month (it may have been the same spot actually), but still some nice movement, appearance, disappearance can be seen I think, or I am just lucky the time I observe it.
Thanks for sharing your beutiful images.
Alexandros
Alexandros
Alexandros
Greece
Greece
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Beautiful image, Raf.
Since I have Photoshop, I took the liberty of removing some of the gradients.
I hope you approve!
Peter
I hope you approve!
Peter
- krakatoa1883
Thanks, Peter, now is much better! I don't have PS, I am using GIMP but the gradient tool is complicated, I don't like it.
Raf
