Animation of Penumbral Waves
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Post by H-Alpha »
Hi all,
In the post with the 1h animation of two days ago (17 June 2021), Filip made an interesting observation and comment. He noted that Penumbral waves were visible around the spot. I didn't know about this phenomenon neither the term until that moment. Excited that somebody show me something new to me, I wanted to share it with you. It seems there are several scientific papers about the penumbral waves.
They were just visible in my original animation and the experienced eye of Filip got them. I played much faster the animation et Voila! They are much better seen now in the cropped Gif, especially in the northern part of the spot.
PLEASE give the animation the time to load properly. It is 1 hour animation.
Animation of penumbral waves, 2021-6-17.gif (13.45 MiB) Viewed 399 times
If somebody wishes to add a few more words about the Penumbral Waves is very welcome!
Alexandros
Alexandros
Greece
p_zetner
Has thanked: 166 times
Been thanked: 719 times
Re: Animation of Penumbral Waves
Post by p_zetner »
Thanks for providing the crop at higher frame rate.
Th waves are clear to see.
Peter
Has thanked: 17807 times
Been thanked: 16942 times
Post by DeepSolar64 »
WoW!! This is amazing! Proof that amateurs can do professional quality work. It's amazing what we can now image and nothing reveals the Sun like a good animation does. I wonder if anyone here has captured Moreton waves?
https://en.wikipedia.org/wiki/Moreton_wave
Has thanked: 8523 times
Been thanked: 8252 times
Post by Carbon60 »
Excellent capture of these delicate waves, Alexandros.
H-Alpha
Post by H-Alpha »
Thanks a lot Peter, James, Stu,
@James: Thanks for the link on Moreton_waves! The solar Tsunamis! Let's see if we will observe and record them the following years towards the maximum ;-)
Alexandros
Alexandros
Greece
You are welcome Alexandros. This was an outstanding animation of penumbral waves!
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Post by Ivan »
Fantastic animation, very nice and clear.
Ivan
H-Alpha
Post by H-Alpha »
Thanks a lot James and Ivan,
@James: Many thanks once more. Hope to be able to have a proper Barlow or telecentric soon, to make magnified animations. Better and larger penumbral waves will be a feasible goal then. It is still not clear for me if FFC or Baader telecentric 4X or some other Barlow would be the best choice.
Alexandros
Alexandros
Greece
Has thanked: 17894 times
Been thanked: 8887 times
Fabulous work! :bow :hamster: Moreton waves are a little more difficult, you have to be doing continuous animations of the whole Sun to achieve this. This was studied by Thomas Ashcraft in the USA who has seen this many times http://www.heliotown.com/Moreton_wave_Ashcraft.html
H-Alpha
Post by H-Alpha »
Thanks a lot Alexandra!
Your link helps a lot. I thought they last much more time, but if only some 5-10 minutes, the chances to capture them one day increases. Of course they do not occur so often and much luck is needed, but as the solar activity will be increasing until the maximum, maybe someone of our community making long animations may capture them. Of course as you say the animation should cover a very large portion of the sun around an active area and have the chance to capture the flare that will produce them. ;-)
Alexandros
Alexandros
Greece
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Excellent Alexandros
H-Alpha
Post by H-Alpha »
Thanks a lot Franco!
Alexandros
Alexandros
Greece
