Hello,
I am been spending most of my last solar sessions playing with the Sol'Ex spectro and testing the bandpass of solar Ha filters. The results are interesting ...
The spectro is also very usefull to check the tuning of the filters on Ha line. In fact, it proved that the tuning with the Ha lamp was right on spot :-)
I had a quick imaging session on June 16 with good seeing condition. We can seen a lot of small umbral dots in the sunspot.
http://astrosurf.com/viladrich/astro/so ... B1920..jpg
Clear skies
Christian
AR2883 on June 16 with the Hat 8 and double stack Ha
- Been thanked: 2725 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Re: AR2883 on June 16 with the Hat 8 and double stack Ha
Beautiful result, Christian.
It will be interesting to see what you have come up with in the filter testing!
Peter
Peter
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Excellent Hi-Res results as always Christian!
Thanks for sharing.
What SSM did you have for this photo?
Alexandros
Thanks for sharing.
Alexandros
Alexandros
Greece
Greece
Excllent result, Christian. As always.
Why don't you use your C11?
Thanks to all :-)
Peter, regarding filters, I probably need one or two more weeks to put things together.
Alexandros, as I was also busy with Sol'Ex spectro, I didn't install the SSM (to many things to do ...). BTW, I received your last pm and try to answer soon.
Valery, unfortunately, the Hat 11 I had years ago was only for testing. I should have kept it ;-)
Christian
Christian
- Been thanked: 10489 times
Top drawer stuff Christian!
- Has thanked: 9326 times
- Been thanked: 6158 times
- cmas
- Has thanked: 294 times
- Been thanked: 248 times
Wow!
Images in AstroBin
Images in Flickr
Images in AstroBin
Images in Flickr
