111 minutes animation of AR12833 - Penumbral waves and Ellerman bombs? 19 June 2021
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Dear all,
Today I tried a longer animation. The goal was 3 hours, but clouds that came from nowhere decided otherwise, so the goal remains alive for another day. ;-) I could go up to 111 minutes, almost 2 hours. Although our friend Minh explained this a couple of days before, I had to take my lesson in practice! After about 45 min I was already out of focus because of temperature change... Fortunately I realized that and corrected focus later, but part of the animation is not as clear as it could. However, it seems to me it is still beautiful and has useful information.
I captured the entire NW quarter of the sun with both the AR and beautiful proms. Here I cropped the capture to focus on AR12833 and I may present the entire frame later. MANY penumbral waves are visible and many Ellerman bombs as well? Are they? If not what are all those flashing white points around the penumbra?
Lunt130MT masked @102 mm. 115 frames in 111 minutes. Average SSM started at 2" and dropped to 1.5". PLEASE allow enough time for the animation to load properly. (You won't regret it ;-) ) Hope you will like it and all comments are very welcome as always! ;-)
Alexandros
Alexandros
Alexandros
Greece
Greece
- Has thanked: 17845 times
- Been thanked: 16977 times
Re: 111 minutes animation of AR12833 - Penumbral waves and Ellerman bombs? 19 June 2021
Alexandros,
It looks like you have clearly gotten the penumbral waves and with a close look I can see the Ellerman bombs coming and going too!
Keep at this. This is interesting stuff!!
- H-Alpha
Thanks a lot James for the encouragement and your confirmation for the Ellerman bombs!
Alexandros
Alexandros
Alexandros
Greece
Greece
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Penumbral waves, penumbral flow, penumbral bright points (not sure if they are Ellerman bombs)….What a spectacular animation!
Keep striving for perfection!
Peter
Peter
- Been thanked: 4971 times
Alexandros:
A super clean and crisp animation.
What a show, thanks.
- Has thanked: 9307 times
- Been thanked: 6144 times
Very well done and a real pleasure to watch !
- pedro
- Has thanked: 14 times
- Been thanked: 6689 times
Great stuff, well done
Pedro Re'
- cmas
- Has thanked: 294 times
- Been thanked: 248 times
This looks so very nice and there's a lot to see! I know it has not turned itself to this final animation so thank you for your great effort and sharing this!
Images in AstroBin
Images in Flickr
Images in AstroBin
Images in Flickr
- Has thanked: 6296 times
- Been thanked: 7308 times
Very beautiful and interesting animation! Great work!
Arne
Arne
- Been thanked: 2725 times
Very well done !
Is this the original size of acquisition or have you done some resizing for posting it on the web ?
- H-Alpha
Thank you all so much for your kind words Peter, Eric, Franco, Pedro, Tommi, Arne, Christian!
I can reconvert m4v files of my large animations and then resize and compress them as gifs, but then they loose a lot of their details and information...
Any idea on what to do without overloading the chat is very welcome!!! I hope I have answered your question Christian. If not please let me know.
Alexandros
Christian this is just a crop of the original captures around the AR. I attach below one frame of the original work. I am really desperate because I wish to upload the full size animation, which is interesting, but it is 135Mb. I spent all the day looking for ways to make it smaller and as m4v file it becomes just 9Mb. The problem then is that it does not loop... I just created a flicker account to upload my results there, but just realized that flicker does not play the gifs! :-(christian viladrich wrote: ↑Sun Jun 20, 2021 7:23 pm Very well done !
Alexandros
Alexandros
Greece
Greece
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
Alexandros, thank you, such a wonderful show!
Ivan
Ivan
- H-Alpha
Thanks a lot Ivan!
Very glad you enjoyed it.
Alexandros
Alexandros
Alexandros
Greece
Greece
- Has thanked: 17970 times
- Been thanked: 8905 times
Alexandros, Flickr does play the gifs but not on the preview pane. You have to go to 'view all sizes' and click 'original'. Same to display here, when you obtain the BB code pick 'original'
- H-Alpha
Thanks a lot Alexandra!!!
You helped a lot with your advice regarding Flickr as you will see in my new posts.
Alexandros
Alexandros
Alexandros
Greece
Greece
