I have been trying to figure out how to double stack my Lunt60THa solar telescope with 60 mm doublestack filter. So far I have not reached zen kind of state of mind with this filter. I tried to make marking on filter and telescope during last imaging session, as I assumed I almost had everything right. Since spring time I have kept trying during good seeing and personal mood. Solarchat offered little comfort, and now I seek your guidance!
Here is one test result with Lunt60THa + 60 mm double stack and ASI178MM. No flats or tilt adapter. In this picture I get least "banding issue", so is it just more filter position adjustment needed? I can see contrast improve on live screen when I adjust doublestack filter's position.
In case there might be some kind technical issue, here is how solar telescope itself perfroms, ,same observation day.
Below is image with single stack setup, with barlow and flat used. Otherwise same gear (Lunt60THa, Powermate barlow 2.5x, ASI178MM).
Any kind of help is valuable, just like this double stack filter was
Lunt60T Ha Double stack issue
- Petrus
- Has thanked: 1597 times
- Been thanked: 769 times
~ Petrus ~
Flickr
Flickr
- Has thanked: 17863 times
- Been thanked: 17007 times
Re: Lunt60T Ha Double stack issue
Sassy,
It looks like you are tuned to the " surface " features and may be a little off band for the filaments. I have trouble giving you advise on this because I have the same problems you do with tuning with double stack concerning imaging. I tend to tune first visually before putting the camera on but even then the camera often shows uneven illumination which doesn't often seem to show up as much visually so I will go tweaking the etalons. I find it so hard to get it right with DS and imaging. I'll often get frustrated and go single stack which is much easier to tune.
I know I am no help. Sorry.
James has recognized the issue with DS-ing your LS60 and DS60.
I have exactly the same set-up as yourself (in Finland) and although currently I am not using the DS, I know that tuning of both Etalon's can be a challenge to get the "sweet-spot" - it simply requires more practice.
Bear in mind that for prominences, single-stacking gives the best result, whereas DS-ing is primarily for better surface detail and it's contrast for that purpose...
Some have recommended turning the DS in the scope by a suitable amount (with care not to loosen it too much of course) and by stages of that, take more images to see if it corrects the situation. If that proves successful, then to count those turns from fully-in and mark both sides of the DS and scope for future use..
Also to inspect the DS to make sure there is no apparent 'fogging' of the optics. The DS itself should always be kept in a dry atmosphere in its' case and with a Silica Gel pack when not in use for any lengthy- period...
I hope these two points will give you a satisfactory-resolve to your issue.
- Petrus
Thank you James and Terry! I will continue with my trial and error. I do have M6 rotator wich helps finding correct position without risk of dropping the double stack filter itself. I tested without and with it.
I agree single stack Lunt60 is just most fun way for casual or long period imaging. I miss those not so hot early summer days...!
~ Petrus ~
Flickr
Flickr
Yes, here in S.E.England, it generally has been wet and cloudy, cold or too-cold, foggy, windy or very windy and very occasionally far too hot, but there's not much we can complain about really - cus no-one will listen...!!!
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Sassy, as James has stated you look off band slightly on your single stack image. I would follow the advice that Terry has suggested.
Here are my suggestions.
Remove your front etalon and fine tune your rear etalon until you get the most contrast on your solar disk. Lower your exposure to reveal as much detail on the disk as possible. You should then see the spicule layer on the edge of the disk(you wont see it when double stacked). When you are satisfied with your image put the front etalon on your scope and fine tune your front etalon for the best contrast, you may have to rotate the etalon to reduce banding. In single stack you can also do off band imaging to emphasise different solar features.
Here is a live capture from last week.
Martin
Martin
- Petrus
Wow! Thank you a lot Martin! I hope I could get better results with this help. I will post results when I get some some H-alpha time.Martin_S wrote: ↑Sun Jun 20, 2021 9:34 pm Sassy, as James has stated you look off band slightly on your single stack image. I would follow the advice that Terry has suggested.
Remove your front etalon and fine tune your rear etalon until you get the most contrast on your solar disk. Lower your exposure to reveal as much detail on the disk as possible. You should then see the spicule layer on the edge of the disk(you wont see it when double stacked). When you are satisfied with your image put the front etalon on your scope and fine tune your image for the best contrast, you may have to rotate the etalon to reduce banding. In single stack you can also do off band imaging to emphasise different solar features.
~ Petrus ~
Flickr
Flickr
Thanks Martin. I will utilize your advise too!
Many thanks Martin for your additional information on how to.
- Martin_S
Thanks Terry and James, please note that I have edited my original post , I have substituted the word "image" with "front etalon" .
Martin
Martin
