Sun FD in H-Alpha and CaK 19th of June 2021
arnedanielsen
Has thanked: 6276 times
Been thanked: 7289 times
Post by arnedanielsen »
Hi all,
After being cloudy for the most of the day it cleared just long enough in the afternoon to grab a few shots. It was quite humid and hazy, but the seeing was good.
FD image in H-Alpha using the Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO.
Sun90FD_145545_Ha_(Coronado_90mm_BF15)_20210619_ZWO ASI1600MM Pro_lapl4_ap6081_Sharpened_Contrast_resize.jpg
Sun90FD_145545_Ha_(Coronado_90mm_BF15)_20210619_ZWO ASI1600MM Pro_lapl4_ap6081_Sharpened_Contrast_resize.jpg (455.39 KiB) Viewed 277 times
Full size image
FD image in CaK using William Optics ZenithStar 61II stopped down to 46mm, Lunt Cak 1200 module and ASI 178mm camera.
SunCaK60_153713_CaK_(3934nm)_20210619_ZWO ASI178MM_lapl4_ap2799_out_Contrast_resize.jpg
SunCaK60_153713_CaK_(3934nm)_20210619_ZWO ASI178MM_lapl4_ap2799_out_Contrast_resize.jpg (278.48 KiB) Viewed 277 times
Full size image
SunCaK60_153713_CaK_(3934nm)_20210619_ZWO ASI178MM_lapl4_ap2799_out_Contrast_Colorized_resize.jpg
SunCaK60_153713_CaK_(3934nm)_20210619_ZWO ASI178MM_lapl4_ap2799_out_Contrast_Colorized_resize.jpg (305.31 KiB) Viewed 277 times
Full size image
Arne
Arne
Ivan
Has thanked: 3472 times
Been thanked: 2251 times
Re: Sun FD in H-Alpha and CaK 19th of June 2021
Post by Ivan »
Hi Arne
Very nice and contrasting FD. Are granules visible in the full-size picture (in the calcium line)?
Ivan
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Very fine full disks Arne, thank you...
arnedanielsen
Thank you Ivan and Franco.
Ivan: I don't think so. I'm not sure if the resolution is to low or if they are visible at all in CaK. Maybe someone else knows this better.
Arne
Arne
Has thanked: 20738 times
Been thanked: 10430 times
Nice shots Arne! I can just about make out inverse granulation at 40mm when seeing and sampling are absolutely optimal. It's easier at 60mm though. (not 60mm f6 though - try 60mm f16!)
arnedanielsen
Thank you, Mark!
Arne
Arne
