Session time is from 14:29 to 15:25 UTC. The skies are partly cloudy. The seeing is above average and the temperature is 80F.
Coronado SolarMax II 90 DS. 32x, 44.5x and 64x ( Ha )
I can see almost all the detail seen on the GONG Cerro Tololo Ha image today! AR12833 in the NW shows it's spot being surrounded on three sides by plage. N-W-S. A long dark filament lies to it's east. NE of that long filamet is an easy " patch " filament.
I can see a tiny eye shaped plage in the south just across the CLM and another tiny plage in the SE. I can see some " ruffleage " with associated filaments in the SW. I can also see a slight amount of ruffleage in the NE.
Outside of the aforementioned filaments I can see small ones in the far south, one in the NE and two more in the NW. One of those in the NW is an easy to see filaprom!
I can see 5 nice but small prominences in the NW. The second from the top is a filaprom. I can also see some small ones in the east-southeast.
The mottles are easy today and I can see the spicule layer on the limb.
Celestron NexStar 102GT w/Altair wedge and 540nm filter. 55x, 110x and 166.5x ( WL )
The large spot of AR12833 shows nice detail. Despite a report of a light bridge through the umbra I could not see one. I can see irregularities in the umbral edge though. The penumbra shows nice detail. Radial lines are easily seen. I can see seven pores near the large spot. One to the north is elongated.
A patch of faculae lies near the SW limb.
I can see the individual granules. 110x gives the best view. The seeing is messing with the higher magnification in the 6mm Delos eyepiece.
Carpe Diem!
June 21 2021 Observations.
- Has thanked: 17845 times
- Been thanked: 16977 times
- Has thanked: 8543 times
- Been thanked: 8280 times
Re: June 21 2021 Observations.
Thanks, James.
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
Excellent viewing session, James. It's always a little sad when AR weakens or approaches the limb.
Ivan
Ivan
Thanks for reading my report, you guys.
- Has thanked: 20779 times
- Been thanked: 10462 times
Glad you're getting some views in James and thanks for the report. Starting to claw some time back into my life now, but is cloudy
- Has thanked: 17970 times
- Been thanked: 8905 times
Lovely report James, nice to hear there is still plenty to see
I wondered where you have been, Mark.
I have clouds today. I am hoping for at least a white light view. It doesn't look good though.
Work, work, work, work, work... Been manic...
Slightly less manic now though, so hoping to be back here a little more like normal. I miss my solarchat
Working does get old after awhile. I understand that!
