AR2833 and FDs in various lights 22nd June 2021
- Has thanked: 8559 times
- Been thanked: 8297 times
The morning started off beautifully clear, giving me a great opportunity to observe/image across the spectrum at various image scales, although, as is often the case, the seeing conditions let things down and some of the closer view images came out a bit soft. Best not to over-sharpen in these circumstances.
Anyhow, here are the resulting images.
CaK FDs on a 72mm f6 stopped down to 40mm.
Basler acA2440-75 um
1.5x Barlow
20210622_CaK_FD_Mono by Stuart Green, on Flickr
20210622_CaK_FD_colour by Stuart Green, on Flickr
Closer views of AR2833 (or AR12833 if you prefer)
Tecnosky 125
acA2440-75 um
2.5x Barlow
20210622_CaK_AR2833_Mono by Stuart Green, on Flickr
20210622_CaK_AR2833_colour by Stuart Green, on Flickr
Ha FDs on a TS Lunt 60
1.5x Barlow
20210622_Ha_FD_Mono by Stuart Green, on Flickr
20210622_Ha_FD_Colour by Stuart Green, on Flickr
Closer view of AR2833 with beautiful, long, filament captured on a 150mm/DS Lunt35 mod
Basler acA1920-155um
2.5 x PowerMate
20210622_Ha_AR2833_mono by Stuart Green, on Flickr
20210622_Ha_AR2833_colour by Stuart Green, on Flickr
Closer still using a x5 PowerMate, pushing my luck. This is a stack of stacks to try to get the best image I could under deteriorating conditions.
20210622_Ha_5xPM_AR2833_Inverted_Mono by Stuart Green, on Flickr
20210622_Ha_5xPM_AR2833_Colour by Stuart Green, on Flickr
Finally, the same region in green light (540nm) with a Lacerta Wedge and Tecnosky 125mm refractor.
20210622_WL_AR2833_mono by Stuart Green, on Flickr
20210622_WL_AR2833_colour by Stuart Green, on Flickr
Thanks for looking.
1.5x Barlow
Tecnosky 125
acA2440-75 um
2.5x Barlow
1.5x Barlow
2.5 x PowerMate
Thanks for looking.
- Rusted
- Has thanked: 8172 times
- Been thanked: 1943 times
Re: AR2833 and FDs in various lights 22nd June 2021
High quality images. All of them!
The close-ups are spectacular!
- Been thanked: 8907 times
Cracking images Stuart wow! to image, process and post, all before lunch, I am very impressed
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Great images, Stu, excellent work. H-alpha is particularly beautiful and well processed.
Raf
- Has thanked: 20828 times
- Been thanked: 10502 times
Very nice set Stu! I was greeted with the eastern sky cloudy just after dawn today so wasn't able to capitalise. Fingers crossed Wednesdays forecast is right and I get a chance then.
Excellent captures Stu.
Thanks for sharing
Thanks for sharing
- Been thanked: 4981 times
Stu:
Superb work in spite of seeing conditions.
- Has thanked: 17860 times
- Been thanked: 17004 times
Stuart,
I love all of your images but your CaK images stand out to me. I lack CaK capability as of yet and CaK is not a visual wavelength anyway so I find your CaK images quite informative.
Thanks!
Thanks!
Thanks, Alexandra. To be fair, I do have a little more time these days
I do hope so, Mark. Good luck with the weather.marktownley wrote: ↑Tue Jun 22, 2021 2:30 pm Very nice set Stu! I was greeted with the eastern sky cloudy just after dawn today so wasn't able to capitalise. Fingers crossed Wednesdays forecast is right and I get a chance then.
Great images Stu. I have not seen the Sun for almost a week down here in SE England, good to see what I've missed
John
John
Many thanks, Rod/John.
- Has thanked: 6305 times
- Been thanked: 7327 times
- Has thanked: 150 times
- Been thanked: 295 times
Really nice images Stu. The 2.5x and 5x Ha are especially beautiful. “Stacking stacks” ? How many stacks did you stack?
The colored white light (green light) is very nice. You hit a great color that is pleasing and brings out great contrast.
- Has thanked: 1277 times
- Been thanked: 1070 times
Great all images, Stu!
I did imaging right at the same time like you , always interesting to see it. Excellent processing!
regards
Leo
regards
Leo
Many thanks, Arne, David and Leo.
Hi David,
I took seven SER sequences, processed these to produce seven tiff images and stacked these.
- Has thanked: 9327 times
- Been thanked: 6163 times
Excellence in solar imaging, Stu ! A great set at the various frequencies.
Many thanks, Franco.
