I got a Lunt 50!
- davidem27
- Has thanked: 81 times
- Been thanked: 247 times
I got a Lunt 50!
Hello everyone!
I recently purchased a used Lunt 50 with PT and a modified helical focuser and I am really happy!
I want to try to figure out the quality of its parts and I would be glad to submit its fresh results to your attention.
Here it is the latest image I took this morning, processed via ImPPG (RL 1.08, 50 - UM 1.65) and a little touch of curve.
Then I merged disc and proms in Photoshop.
Inspite of images obtained with a Lunt 60 (of a friend of mine), this Lunt 50 gives me more "flatty" images.
Considering this is not a brand new telescope, what could be the reasons?
Thanks for your attention
- 2021-06-22-1003_Sun_Ha_Lunt50_pistr.jpg (656.09 KiB) Viewed 474 times
Calcium II K: Lunt B1200
www.volpetta.com
www.volpetta.com
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Re: I got a Lunt 50!
I think your image looks good. No idea what a "flatty" image is.
Dan
South central Indiana
USA
USA
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Lovely first light with your new scope. I take it you mean even illumination when you speak of flat image? Thanks for sharing.
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- davidem27
Exactly, Stardust.
Thanks for explaining better than me
These are past images of 26th of March, took with Lunt 60 and ASI174 and ASI178, processed only with ImPPG.
They seem a little bit less even illumination (and would like to understand why)
- 178
- 2021-03-26-1139_178_pistr.jpg (619.02 KiB) Viewed 455 times
- 174
- 2021-03-26-1058_174_pistr.jpg (264.2 KiB) Viewed 455 times
www.volpetta.com
www.volpetta.com
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Great photo.
I see you managed to catch the focus.
I look from a smartphone, but it seems to me that I see weak Newtonian rings. Flats can help remove them and make the background more uniform.
I really like your HDR, by the way, (maybe it will be useful) in ImPPG you can make proms visible by process7ing the file with the surface and not removing the proms separately.
Ivan
Ivan
- Ivan
You may not have screwed on the pressure tuner.
Set the shutter speed a little longer than usual (it will be easier to see) and try turning the tuner knob. You can see how the surface darkens or becomes light, for me it usually happens at the edge of the frame.
Ivan
Ivan
- davidem27
Yes Ivan, weak Newtonian rings are present and they are going to upset me...
I'll try to put a tilter after the BF but I'm afraid to not reach the focus anymore.
In this image (the first in the first post) I used the camera with its 1,25 nose and inside of it, the VIP barlow module just to increase a few the sampling.
Oh! I have to check it out! Thanks!Ivan wrote:in ImPPG you can make proms visible by process7ing the file with the surface and not removing the proms separately.
Ivan wrote: Set the shutter speed a little longer than usual (it will be easier to see) and try turning the tuner knob. You can see how the surface darkens or becomes light, for me it usually happens at the edge of the frame.
www.volpetta.com
www.volpetta.com
- Been thanked: 8793 times
- Ivan
Tilter is optional. Try to take calibration flats footage. Here is the instruction: https://m.youtube.com/watch?v=h6GjwHtRK80&t=3s
Ivan
Ivan
- davidem27
Superb! Another processing step. My visual observing nature is gonna kill me
www.volpetta.com
www.volpetta.com
- Has thanked: 17581 times
- Been thanked: 16697 times
Congratulations on the new Lunt 50!
- Been thanked: 10248 times
Your just seeing the scopes sweet spot with the 178.
- davidem27
Hello Mark,
and this is a little movie from yesterday, made to try to better understand just its sweetspot: https://youtu.be/3bKR2ba24BE
www.volpetta.com
www.volpetta.com
- Ivan
Try placing the Sun in the left corner of the frame (as in your video) so that part of the disc loses detail and turns white. And spin the tuner a little at a time. This method helped me get rid of the "overexposed" zones or greatly reduce their area.
Ivan
Ivan
