June 18, 22 2021 AR12833 WL C11
LeoD
Has thanked: 1277 times
Been thanked: 1070 times
Post by LeoD »
Hi all
2 images of the same AR12833 made on June, 18 and 22, with C11 setup.
Both sessions with Aries DERF instead of front solar filter, UV/IR+Baader SC and ASI174. The only difference is ES 3x extender in the first case, TZ-4 in the second one. 0 gain, 0,15-0,2ms only. Than I changed to Ha with Quark, but not processed yet. I suppose TZ gives better picture regarding the same seeing.
regards
Leo
June 18
June 18
Sun_20210622 101305_AId2Ps_850.jpg (446.9 KiB) Viewed 750 times
June 22
June 22
Sun_20210622 100102_AIdPs_850.jpg (401.86 KiB) Viewed 750 times
Freddie
Has thanked: 38 times
Been thanked: 185 times
Re: June 18, 22 2021 AR12833 WL C11
Post by Freddie »
Nice images. It’s interesting to compare what you get from your 11 Vs my 9.25. I think capture and post processing will however have a significant impact on the final image though.
Freddie
Ha: 152mm, Quark, ASI174m
WL: CPC9.25, ASI120m
Has thanked: 9292 times
Been thanked: 6128 times
Post by ffellah »
An exceptional close up, Leo. Large difference between the first and second image, though.
Has thanked: 20738 times
Been thanked: 10437 times
Interesting comparison Leo... Are both post processed the same? The first seems like it is sharpened at a larger kernel size.
Has thanked: 17925 times
Been thanked: 8891 times
Absolutely delightful :bow :bow :hamster: I think I prefer the first image though :)
Valtori
Has thanked: 312 times
Been thanked: 182 times
Post by Valtori »
Very pleasant WL shots!!
First one is the winner!)
Val
H-Alpha
Has thanked: 1674 times
Been thanked: 982 times
Post by H-Alpha »
Impressive Hi-Res Leo!
I was thinking about buying the TZ-4. Do you have it for along time? Is it really good and useful?
Do you think it is useful only for Hi-Res scopes or it could work with the Lunt130 as well?
I am eager to see your photo with in in H-alpha.
Thanks for sharing.
Alexandros
Alexandros
Greece
arnedanielsen
Has thanked: 6276 times
Been thanked: 7294 times
Post by arnedanielsen »
Excellent high-res Leo. I also like the first one the best!
Arne
Arne
LeoD
Re: June 18, 22 2021 AR12833 WL C11 Ha added
Post by LeoD »
Thanks to all for your kind comments!
Well, I have to be more accurate with comparison, Mark, making all processing in the same way, but at least I see your different opinions )
Alexandros, I used TZ-4 some time only in Ca and WL, I can say I like what came out at all.
Now I almost finished to work out hi-res files in Ha from June 18 and 22, nothing to compare because of better seeing on 22 and, at the end of session with mostly ruined conditions, I catched bright Ellerman bomb right on the forming light bridge in umbra part of AR12833 spot.The all phenomenon cycle was visible withing 3-4 minutes, that's why I suggest it's EB, not a surge-like plasma ejections directly towards up, when significant flux change over hours. It was very bright and clearly visible in Ha core, not in shared blue wing under fibrils of chromosphere around AR, as usual. Magnetic flux reconnections should be very strong there in the umbra area.
The setup is the same as above, Quark with 0.5x, EB images without, cropped.
I can't make all nice, dark, long filament together with AR area, because of not stable seeing and forced to cut off a big part.
To see mosaic in full resolution, click on, please. I made proportions also to fit better your smartphones screens :)
thanks for looking
Leo
mosaic
mosaic
Sun 20210622 103440 104801 C Ps_AI.jpg (1.77 MiB) Viewed 662 times
AR12833
AR12833
Sun_20210622 105431_cAIdOPs.jpg (507.99 KiB) Viewed 662 times
EB
EB
Sun_20210622 114107_114442 AIwOP67.jpg (282.39 KiB) Viewed 662 times
WOW!! :shock:
Post by ffellah »
Stunning ! Both detail and contrast…
Franco :bow
cmas
Has thanked: 294 times
Been thanked: 248 times
Post by cmas »
Nice and very detailed stuff!
Images in AstroBin
Images in Flickr
Valtori
Post by Valtori »
Very amazing mosaic and AR12833 shot!!
Val
krakatoa1883
Has thanked: 153 times
Been thanked: 496 times
Post by krakatoa1883 »
Top H-alpha images, really impressive!
Raf
Has thanked: 64 times
Been thanked: 4407 times
Post by MapleRidge »
Outstanding series of image Leo...excellent work :bow
