Heads up, new AR is quite active 23rd June
- Stardust5858
- Has thanked: 803 times
- Been thanked: 1182 times
Just managed to capture a burst of activity within the new AR region. Apologies for the bad images. these are just one frame. My focuser decided to literally fall apart and cogs fell off the electric focus right at the inopportune minute. These were framed at 10.54-10.58UT.
- Sun_115831_F_00000921.png (4.04 MiB) Viewed 507 times
- Sun_115643_F_00000912.png (621.5 KiB) Viewed 507 times
- Sun_115400_F_00000807.png (1.99 MiB) Viewed 507 times
Lunt 60mm Double Stack HA
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
12inch OO Newtonian.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Has thanked: 17853 times
- Been thanked: 16998 times
Re: Heads up, new AR is quite active 23rd June
I got a alert for a C class flare just a little while ago.
- Stardust5858
Brilliant James. Seems an active region.DeepSolar64 wrote: ↑Wed Jun 23, 2021 12:12 pm I got a alert for a C class flare just a little while ago.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Thanks Ella for the action from the new AR.
Sorry to hear about the maintenance-moggy not looking after the focuser... !!!
So much for the benefits of manual focusing though...?
Best Wishes
Best Wishes
- Been thanked: 10489 times
Good result for a broke focuser!
- Stardust5858
I know, you'd think my assistant would have checked everything before observing began, lol.EGRAY_OBSERVATORY wrote: ↑Wed Jun 23, 2021 1:52 pm Thanks Ella for the action from the new AR.
Best Wishes
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Thanks Mark, maintenance needed tomorrow, lol.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Ivan
- Has thanked: 3485 times
- Been thanked: 2263 times
Despite the annoying problem with the focuser, you did it. Great view. Which telescope is this Lunt60 + DS?
Ivan
Ivan
- Has thanked: 8559 times
- Been thanked: 8291 times
Nice capture, Nigella.
Hope you can fix your focuser.
- Stardust5858
Hi Ivan yes it's a 60mm DS plus I used a 2.5x powermate.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Ivan
Thanks, Nigella.Stardust5858 wrote: ↑Wed Jun 23, 2021 7:41 pmHi Ivan yes it's a 60mm DS plus I used a 2.5x powermate.
Ivan
- Stardust5858
I hope so Stu
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Stardust5858
Hopefully more to follow. I was about to pack up and noticed the AR brightening.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
Neq6 Eq Mount.
2.7m Pulsar Dome.
70mm AR Stellavue.
Eq8 r Pro Mount.
- Martin_S
- Has thanked: 999 times
- Been thanked: 3060 times
Wow you caught it at the right time Nigella, flares always look their best on the edge of the limb. Hopefully your focuser can be fixed.
Martin
Martin
