2.5h Animation of NW Sun and "Tree-Proms", Less discrepancy between SSM-Seeing, 23-6-2021
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Hi all,
Today I noticed that the NW proms were still beautiful and active so I tried the same long animation as yesterday. I made only one change... I was throwing cool water on the balcony and surrounding plants to keep them cool, since temperature reached 38 Celcious... It seems that the results were a bit better, because the SSM had some ups and downs and the image quality seemed to follow them for some 2h. Then deteriorated as usually despite the improving SSM values that went to the bottom once more... It may be related with the thicker atmosphere crossed by the sun as it goes down, but why SSM values do not reflect this?
No Jetstream in our area today as well.
I start with a photo of the 'Tree Prominences' at the NW. I liked them so much as they were dancing! PLEASE open in new tab, for better resolution. Then the SSM to allow for comparisons with yesterday post: viewtopic.php?f=4&t=32382 For the first time SSM and image quality (estimated by PIPP) correlated so well! I kept only the first 2 hours data here, since after that I have the strange phenomenon of Bad seeing during very good SSM values. 2h animation cropped around the proms
2021-6-23, NW Sun Prominence trees, 2h 2 min, 120 frames, 17_20_42 by H- Alpha, on Flickr
and the full 2.5 hours animation of the full frame of the NW sun today
2021-6-23, NW Sun and AR 12833, 2h 27 min, 151 frames, 17_20_42 by H- Alpha, on Flickr
Alexandros
Alexandros
Alexandros
Greece
Greece
- Has thanked: 17581 times
- Been thanked: 16696 times
Re: 2.5h Animation of NW Sun and "Tree-Proms", Less discrepancy between SSM-Seeing, 23-6-2021
Alexandros!
These are great! The animations run smooth and show a lot of detail. The color you used is really nice too. That Lunt 130MT does very well!
- Been thanked: 8792 times
You are getting better and better I love the dancing trees
- Ivan
- Has thanked: 3465 times
- Been thanked: 2250 times
Hi Alexandros,
Nice and smooth animation. 2.5 hours of the Sun's life, such a huge amount of work on shooting and processing. You are definitely breaking new records. I always watch your videos with great interest. You're doing fine.
Ivan
Ivan
- Been thanked: 10248 times
Looks good!
- Has thanked: 6181 times
- Been thanked: 7142 times
It's so fascinating to see these timelapse animations. Keep up the good work!
Arne
Arne
- H-Alpha
Thank you all, James, Alexandra, Ivan, Mark, Arne for your kind and encouraging words!
I feel so lucky and happy that I entered into the "solar game" this period and I subscribed in SolarChat, since the best is to come!!!
The 25th cycle has just begun and I got my scope at the right moment to be trained, so that I can enjoy together with you the solar party that is ahead of us!
Alexandros
Alexandros
Alexandros
Greece
Greece
- pedro
- Has thanked: 14 times
- Been thanked: 6577 times
Great animation Alexandros
Pedro Re'
- H-Alpha
Thanks a lot Pedro!
Congratulations for the SPOD today!
It is fantastic!!!
Alexandros
It is fantastic!!!
Alexandros
Alexandros
Greece
Greece
- Has thanked: 8418 times
- Been thanked: 8164 times
Superb animation sequences, Alexandros. You’re coming along in leaps and bounds.
- krakatoa1883
- Has thanked: 153 times
- Been thanked: 496 times
Fine animations, as usual, the prom closeup is really great.
Raf
- H-Alpha
Thanks a lot Stuart and Raf for your kind and encouraging words!
Alexandros
Alexandros
Alexandros
Greece
Greece
- davidem27
- Has thanked: 81 times
- Been thanked: 247 times
There must be a lot of work, Alexandros!
But every drop of sweat worth it!
What software do you use to create this videos?
Calcium II K: Lunt B1200
www.volpetta.com
www.volpetta.com
- robert
- Has thanked: 4 times
- Been thanked: 1274 times
Wonderful results, thanks
Robert
Robert
- H-Alpha
Thanks a lot Davide and Robert!
I capture with Firecapture. Then Autostackkert!3 (I still have not tried several advanced options). ImPPG for convolution (this takes a lot of time until I have found the best possible curve, because it is a try and error procedure; I save one image then process in Photoshop to see the final results, and then start again if not satisfied). Then Image alignment with ImPPG again. Then Photoshop (batch process with presaved actions) for filters and colour. Finally GIMP (open as layers) to create and save the animation.
Something that I have not managed so far is to normalize the levels of images, so that there is no flickering in the animation. Minh is doing this successfully with PixInSight, but I do not have it yet.
All the best,
Alexandros
Yes, a lot of processing... especially if a couple of captures do not come up right and manual readjustment have to be done. I sleep very very late lately... ;-) (with the first sunlight sometimes...). But I think it is worthy, since nice things come up often and also I can improve methods to be ready for the big party when the maximum will be here. :-) Certainly I cannot go like this for long more. I am doing this now, because in about 10 days I will be away offshore without telescope of course for a long time.
All the best,
Alexandros
Alexandros
Greece
Greece
- Been thanked: 4340 times
Beautiful animation Alexandros
- H-Alpha
Thanks a lot Brian!
I am glad you liked it.
Alexandros
Alexandros
Alexandros
Greece
Greece
- Has thanked: 9145 times
- Been thanked: 6025 times
Beautiful, Alexandros, very well done !
