My biggest project to date
- Has thanked: 60 times
- Been thanked: 78 times
Almost 6 hours worth! 339 movies = 1.93TB. Each movie took over 7 minute to run in AutoStakkert... So yeah, it took a while to process. To be honest, I'm not sure I will do it again
I wish I could fix the wobble!!! Any tips? I tried PIPP and ImPPG, no good
Taken with my Lunt50, asi178mm, Baader Q-Barlow 1.3x (working at 1.4x)
I messed up and uploaded the instagram sped up versions! Fixed now
Mono
https://www.youtube.com/watch?v=81dt4I423uY
Color
https://www.youtube.com/watch?v=Z_HbPrXVJGA
Rotation
https://www.youtube.com/watch?v=rnh49oD6jdU
Mono
Color
Rotation
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
Chris
Lunt LS50THa
- Has thanked: 17853 times
- Been thanked: 16998 times
Re: My biggest project to date
WoW! outstanding work. I know I would never have the time or patience to pull this off.
Thanks! It was a lot of work. Took two days to finish processing it!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
Trying a full disc timelapse is quite a feat well done!!
Have you tried aligning in ImPPG on the solar limb? I ask as you should see the rotation of the Sun over 6 hrs. Alexandros was having this problem and GreatAtractor suggested this and it sorted out the problem. Only an idea.
- GreatAttractor
- Has thanked: 747 times
- Been thanked: 757 times
Unfortunately ImPPG won't stabilize such a wobble... yet. But I've been already thinking about adding derotation in the future.
Thank you!
Awsome that you are looking into it it though, Filip!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
- arnedanielsen
- Has thanked: 6305 times
- Been thanked: 7324 times
Great effort and well worth it! Excellent result, Chris.
Arne
Arne
- Has thanked: 2464 times
- Been thanked: 4880 times
Thank you Maurits
Takker Arne!
Takker Arne!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
- Been thanked: 2725 times
This is impressive and certainly a good idea !
Is it done with an equatorial mount or azimutal ?
Thanks!
It was tracked with my EQ6-R PRO.
The rotation is my favorite as well!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Excellent work Chris and congratulations for your patience and work in that!
If one day I have the ASI1600 for FDs, I may try this.
ImPPG has been very successful in aligning all my animations so far, including the long one of 3 hours. Of course they were not FDs. I don't know if this makes the difference.
Do you improve your captures with ImPPG before aligning them with the same software? Just an idea... This is the procedure that works for me. Autostakkert!3--> ImPPG curve/convolution --> ImPPG alignment
Anyway, I suppose you will keep the frames, since there must be a way and you may resolve this in the near future. :-)
Congratulations once more and best wishes,
Alexandros
Alexandros
Alexandros
Greece
Greece
Thank you Alexandros!
Full disk imaging is a little different I think. I think it depends on the frame AS chooses as a reference. If it is slightly distorted, your whole image will be a little off. So you end up with the wobble when creating an animation. I have never had a problem with closeups
Frames are being kept! Not doing all that work again!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
Very impressive work! And so fantastic patience was applied!
Looking for the images with your lantair.
Thanks.
Thanks.
Thank you Valery!
Yes, I am hoping to bring out the 'Luntair' again soon
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
Thank you!
Clear sunny skies!
Chris
Lunt LS50THa
Chris
Lunt LS50THa
