Hello Ladies and gentlemen,
how do you judge the focus on all over the disc?
https://drive.google.com/file/d/1Sj2_W4 ... sp=sharing
I used the tilter for the first time to avoid Newton's rings and it seems, somewhere on the disc, the focus lacks of precision.
What do you think about?
Focus over Sun disc - Help to solve Newton's Rings
- davidem27
- Has thanked: 81 times
- Been thanked: 247 times
Calcium II K: Lunt B1200
www.volpetta.com
www.volpetta.com
- Has thanked: 17667 times
- Been thanked: 8789 times
Re: Focus over Sun disc
I would have thought that the Sun would have the same focus all over, I've never had a problem with this. However if you are using massive tilt this could be a problem. Certainly the left side looks more out of focus than the right so something is not square
A nice disc though
A nice disc though
- davidem27
Thankyou Alexandra for replying.
Your look puts one heavy cent to my doubts.
The entity of the tilting is definitely thick.
But this was the first position I figured out that removed Newton's ring.
Maybe I have to try again with another angle.
But, sincerely, I don't think it will work.
Do you have any other tip to remove Newton's rings?
www.volpetta.com
www.volpetta.com
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Re: Focus over Sun disc - Help to solve Newton's Rings
Hi Davide!
I was also fighting against the N.R. the previous days, because they appeared with my new Barlow. I thought that because it is a considered quality one would not present N.R.s. I found relatively easy (although tiring...) to remove them with some flats in firecapture, but I never had them in full disks, so there it might be more difficult? Did you try?
Alexandros
Alexandros
Alexandros
Greece
Greece
- davidem27
Hello Alexandros and hello to everyone,
I was away in last weeks so didn't check forums.
I do not know what is the better way to apply flat images to Sun disc images.
I have to find out what are the most common and useful ways.
I saw some youtube videos from a solarchat user but I have to better understand/apply the software process.
How did you tried?
Do anyone else know how to effectively remove Newton's rings from full disk images?
Thanks so much and glad to be here again.
www.volpetta.com
www.volpetta.com
- Has thanked: 173 times
- Been thanked: 615 times
David,
I had a thread on the subject of full disk flats and NR.
viewtopic.php?f=33&t=31335
FireCapture flats worked well, but for ease of use I’ve gone back to using the T2 tilter at maximum angle.
This is with the TV x2.5 PM and the ASI1600.
- Been thanked: 4786 times
David, I need always a tilter when I do Ha imaging.
