In between the "white fluffy stuff" and less than perfect seeing, managed to capture something of the action.
Thanks for looking
Friday 2nd June'21 Captures
- 2021-07-02 1018z CaK.jpg (756.52 KiB) Viewed 351 times
- 2-7-2021 1016z Ha - proms.jpg (133.2 KiB) Viewed 351 times
- 2021-07-02 1050z WL AR2835, 36, 37.jpg (105.53 KiB) Viewed 351 times
- Has thanked: 17581 times
- Been thanked: 16697 times
Re: Friday 2nd June'21 Captures
Thanks Terry for the views. I am waiting for the clouds to clear, It's overcast at the moment.
- dhkaiser
- Has thanked: 1407 times
- Been thanked: 899 times
Thank you James, Dan and chris.
I hope James you get a chance to see this (apparently 20 spot) AR, as both visually and imaging-wise is a nice and interesting capture.
Yes Dan, I agree that due to the less than good weather, it was difficult to get decent views in Ha and CaK, where my primary-aim, was to try-out
X2, X2.5 and X5 Barlow's for that particular scope, but the limit seems to be around 4X (if I had one).
Need a better seeing to retry the same performance-testing though...
I note that the SDO image captured only an hour or so earlier is almost identical to my capture albeit theirs' is a FD.
When the new scope arrives (hopefully in July), that might change, as well as possibly a new camera to follow for WL.
- 2021-07-02 1037z 5X HW-WL.jpg (308 KiB) Viewed 327 times
Corrected Reply
Thanks James, Chris and Dan. I hope you get a clear view soon James...
- 2-7-2021 latest_4096_HMII.jpg (1.45 MiB) Viewed 324 times
- Been thanked: 4787 times
- Been thanked: 8793 times
