SUN 2021/7/2
- p1taylor
- Been thanked: 219 times
SUN 2021/7/2
Hi All, Just managed this but very hissy and cloudy, is there a way to get proms to be coloured not black.
peter
peter
- Has thanked: 17813 times
- Been thanked: 16950 times
Re: SUN 2021/7/2
Nice color!!
- Has thanked: 17925 times
- Been thanked: 8891 times
Re: SUN 2021/7/2
Great images Peter
Why are the proms black, have you inverted them? if so, keep them positive
- p1taylor
Re: SUN 2021/7/2
Thanks all for your comments.
No not inverted Alexandra, if I do thy cone out OK but spot is white.
peter
peter
Re: SUN 2021/7/2
Then I am baffled as to why they are black, the sky should be black and the proms should be white unless you have inverted them. Can you describe how you do your post processing? I am presuming they are white when you see the live view with the camera?
- p1taylor
Re: SUN 2021/7/2
Hi Alexandra, The proms are white in Sharpcap 3.2, camera is ZWO ASI 178 MM, scope is Lunt 60mm h-alpha PT, I stack in Autostakker 3, and process in IMPPG 0.6.3, Photoshop CS3 extended, all so a lot of software from dep sky I did for years, I really appreciate your help as I am not to good with pc.
peter
peter
- Has thanked: 2462 times
- Been thanked: 4878 times
- Been thanked: 4957 times
Re: SUN 2021/7/2
Peter:
Interesting looking images, I am not good for PC work either, so lets see what members of the forum say.
Re: SUN 2021/7/2
Peter, that sounds like the correct path, but we need to know exactly how you do the post processing in Photoshop. Try to follow my instructions in this guide to the letter with your avi and see if you come out with white proms https://solarnutcase.livejournal.com/18572.html
- p1taylor
Re: SUN 2021/7/2
peter
- Has thanked: 9293 times
- Been thanked: 6128 times
Re: SUN 2021/7/2
That's much better Peter! but I can see the sky is still quite grey. I bet you had a little background haze which can result in this grey fuzz. But at t least the proms are white I would just tone down the shadows and highlights a little. Drop down from 50 a bit. Then use a little contrast to reduce down the grey sky glow a little more. It will be a fine balance between getting the proms and losing them to get the black darker.
What gamma setting did you originally take the avi with? it needs to be at a neutral setting at capture. Also what does the histogram look like?
- p1taylor
Re: SUN 2021/7/2
Yes it was a lot of haze, my Sharpcap as not got gamma it has gain set at 0, when I tuck them proms and sun where all on PC.
peter
peter
- p1taylor
Re: SUN 2021/7/2
At last found a way to get my images from ser to jpg so this is one of the images street out of sharpcap not prosiest at all.
peter
peter
Re: SUN 2021/7/2
That's great Peter, you have some superb details in this single image. What you want to achieve is an image equal to or slightly improved on the image captured here. So as you can see the sky is black and the proms are there but white. Anything not the same as the original is not data but art (depends on what you are after).
The only thing I would suggest would be to have a jiggle with the tuning when you are watching the live view, try to get as much contrast as you can as it is a little off band to the lower left. When happy, move the Sun around in the field of view, has the contrast increased anywhere? you will find a spot where it is more uniformly illuminated. At the moment the lower left is brighter than the right and also more off band than the right. This is key to getting an even disc. The more on band you are, the more the proms will naturally stand out too when you post process.
Keep going Peter, you are really coming on in leaps and bounds
- p1taylor
Re: SUN 2021/7/2
Thanks very much for all your help I really appreciate it, do I carry on using flats to get it all same, will defiantly try to do what you suggest.
peter
peter
Re: SUN 2021/7/2
Peter, you shouldn't need to do a flat. It should be possible for you tweek the tuning and move the Sun around and find the best spot. Try it. If it really is impossible then you may need a flat, although I have never mastered a flat yet for a full disc so do tell Mmmm is that why you are getting a funny sky colour? I found all a flat does is reverse everything on a full disc, it doesn't work.
- p1taylor
Re: SUN 2021/7/2
I will try not using flats, I am that uest to doing then just cared on for if there is any bits on lenses.
peter
peter
