New QUARK test, July 2 2021 AR12835 & 12837
Hi all,
It was about a year since I imaged the Sun last time (summer 2020).
On July 2 I managed to test my new Quark Chromosphere with very good homogeneity accross the FOV.
Here are two images (AR12835 and AR12837) taken with this Quark in a following set-up:
ARIES two band DERF D=140mm, SkyWatcher 150mm F/5 refractor, barlow lens which creates about F/35 with Quark's native 4.2x telecentric, focal reducer (about 0,65) and basler 1920-155 camera.
No flat fileld was applied. Contrast and brightness homogeneity are indeed so good that nothing to wish better.
And homogeneity does not changes with CWL tuning knob position changes within -5 to +5 positions.
Also this Quark is very narrow (less than 0.3A in my estimation).
Seeing was average and transparation was low, so low that I were need to rise the camera gain to nearly an upper limit and exposition to 8ms. Invividual frames are quite noisy and dim. I stacked 3500 frames to get a decent S/N.
Right click on the images to open them in a full resolution.
Thanks for looking.
Valery.
Thanks for looking.
Valery.
- AR12835 2021-07-02 UT05h46m ARIES DERF SW150mm @F35 Quark-Chr Basler-1920-155.jpg (308.37 KiB) Viewed 688 times
- AR12837 2021-07-02 UT05h42m ARIES DERF SW150mm @F35 Quark-Chr Basler-1920-155.jpg (422.66 KiB) Viewed 688 times
- Has thanked: 17970 times
- Been thanked: 8904 times
Re: New QUARK test, July 2 2021 AR12835 & 12837
That's a one in a million Valery
Glad to see you back imaging
- Has thanked: 60 times
- Been thanked: 78 times
WOW! Amazing images, Valery!
Clear sunny skies!
Chris
Lunt LS50THa
Lunt "Luntair" Altair 102ED
Chris
Lunt LS50THa
- Has thanked: 1 time
- Been thanked: 2725 times
Excellent Valery !!
BTW, we can now get good estimations of the the FWHM of Ha filters with Sol'Ex spectrograph.
- MAURITS
- Has thanked: 2464 times
- Been thanked: 4880 times
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
I missed your images, Valery!
Great to see them again and these are beautiful.
Great results.
Peter
Great results.
Peter
- arnedanielsen
- Has thanked: 6296 times
- Been thanked: 7305 times
Very impressive images, Valery!
Thanks for sharing.
Arne
Thanks for sharing.
Arne
- Petrus
- Has thanked: 1590 times
- Been thanked: 765 times
Fantastic images, Valery!
~ Petrus ~
Flickr
https://www.flickr.com/people/194757663@N08/
LS80THa DSII - Calcium II K module 12mm - Lunt Herschel wedge 1.25" - Quark Chromosphere - Solarscout Quark - Sol'Ex
Flickr
- Has thanked: 8543 times
- Been thanked: 8278 times
Great to see you back imaging, Valery.
Nice images. I was wondering how many Quarks you tested and rejected befor finding a good one
Thanks to all for your kind words.
To Christian. Nice to know that we some of us now can measure the FWHM of etalons we typically do use.
Question: have you measured your present mica spaced etalons and if yes, do they correspond to the declared FWHM? Same with air spaced etalons and other filters like BF and for CaK. If you have a time, please, give us your findings.
To Stu. I really don't know how many samples were tested. It was not me who tested them. BTW I believe this sample has better than 0,3A FWHM. I compared images taken with it with the images of the same ARs taken through etalons with known FWHM (0.2A, 0.3A and 0.4A).
My is somewhere in between 0.2A and 0.3A. Understandable that this is not really reliable estimations, but I do not have a better method.
- Rusted
- Has thanked: 8127 times
- Been thanked: 1943 times
Superb images!
Is there any way for the humble imager to subjectively judge the quality of their etalons from their own [or other's] images?
Seeing conditions, aperture, objective, filtration, capture, processing and other factors obviously affect the average outcome.
How to judge etalon quality when conditions do allow the finest resolution?
When comparing etalons with intention to judge which is narrower, first of all I look at the filaments length and thickness. The longer and the thinnier filaments are, the narrower the etalon. Second factor to look at is a "fullness" in the "desert areas ". The third factor is a contrast between the spicules and surrounding areas - lesser contrast - better. And forth - contrast between the penumbra and surrounding areas.Rusted wrote: ↑Tue Jul 06, 2021 5:49 am Superb images!
Hope my english allows adequate understanding what do I mean.
- Rusted
Valery wrote: ↑Tue Jul 06, 2021 3:01 pm
When comparing etalons with intention to judge which is the narrowest, first of all I look at the filaments length and thickness. The longer and the thinner filaments are, the narrower the etalon. Second factor to look at is a "fullness" in the "desert areas ". The third factor is a contrast between the spicules and surrounding areas and forth - contrast between the penumbra and surrounding areas.
Thanks you Valery.
Your eloquent description eclipses many whom only claim English as their first language.
Hello Valery,Valery wrote: ↑Tue Jul 06, 2021 5:20 am
Up to now, I have measured :
- one SM 40 mm
- two SM III 60 mm
http://astrosurf.com/viladrich/astro/in ... sting.html
And two Ca K filters :
http://astrosurf.com/viladrich/astro/in ... lters.html
I have two PST in the pipeline.
Very interesting information! Well done!christian viladrich wrote: ↑Thu Jul 08, 2021 2:34 pm Hello Valery,
- one SM 40 mm
- two SM III 60 mm
Thanks for your efforts and time and then sharing these results with us.
- pedro
- Has thanked: 14 times
- Been thanked: 6689 times
Great Quark images, I agree with Alexandra, it's one in a million
My Quark does not have an uniform field, I have to use flats
Pedro Re'
- Been thanked: 4971 times
Valery:
Superb HR images.
As for my Ha filters, I just know that the old ATM that Del Woods made many many years ago is a 4.5A° etalon that has standed many decades and still works good.(this I have it at the rural observatory)
I also have a very old Daystar T-scanner of 4.5A°, that also Del made, and later Jen fitted it in a heated housing leaving the tilter on, this also still works well, though I am getting a central hotspot that could be cured with a new trimmer and blocker.(This I have it at my home observatory in Mexico City)
As for the big Aries ERF for the 10" f/20 TEC Maksutov, it is still in the mounting period, because I am making a cell to use it on the Meade 12" f/10 SCT., unfortunately my very good friend José Villicaña died and left some parts missing, so I am working on those, hope that for the winter period I will have everything ready to go.
Best regards and keep well my friend.
Superb HR images.
Thanks for the info update and for good wishes.eroel wrote: ↑Fri Jul 09, 2021 6:09 pm Valery:
Superb HR images.
Hope your etalons will work well on the 10" MCT.
PS. I believe your etalons are 0.45A°
