Dear friends,
Some images from the 30th of June
FD image in H-Alpha using the Takahashi Sky-90II with Coronado 90mm/BF15, Coronado 2x CeMax and ASI 1600mm PRO
Sun FD in H-Alpha 30th of June 2021
FD image in CaK using William Optics ZenithStar 61II stopped down to 46mm, Lunt Cak 1200 module and ASI 178mm camera
Sun FD in CaK 30th of June 2021
Sun FD in CaK 30th of June 2021 - colorized
CaK imaging using William Optics ZenithStar 61II stopped down to 46mm, Lunt Cak 1200 module, PowerMate 2,5x and ASI 178mm camera
Sun in CaK 30th of June 2021
Sun in CaK 30th of June 2021 - colorized
Click on the links to see full size images.
Thanks for looking,
Arne
Sun in H-Alpha and CaK 30th of June 2021
- Has thanked: 6305 times
- Been thanked: 7324 times
- Been thanked: 4980 times
Re: Sun in H-Alpha and CaK 30th of June 2021
Arne:
A set of very clean and detailed images.
- H-Alpha
- Has thanked: 1674 times
- Been thanked: 982 times
Very beautiful images Arne!
I echo Eric's comment!
Alexandros
Alexandros
Alexandros
Greece
Greece
These are terrific you are getting lots of sunshine compared to the UK, you are very lucky to miss all our rubbish cloud which usually we pass on to you.
