Session time is from 14:30 to 15:03 UTC. The skies are mostly cloudy. Seeing is fair to maybe a bit above average. The temperature is 73F.
Astro-Tech AT72EDII w/Altair wedge and 540nm filter. 24x, 47.5x and 72x ( WL )
AR12842 is visible in the far NE as a single spot showing umbra and penumbra amidst a scattered patch of faculae. No other spots or pores are seen within it. The SE shows a tiny spot with a single nearby pore within a faint E-W patch of faculae. This is AR12841. AR12839 is visible near the NW limb as only a patch of faculae. I can also see a double patch of faculae faintly in the SW.
The fine solar granulation is visible today.
Carpe Diem!
July 12 2021 WL only.
- Has thanked: 17835 times
- Been thanked: 16976 times
Re: July 12 2021 WL only.
Like Maurits, much rain today, this evening and likely for the next days. but thanks for your reports James
Glad to help fill you in, Terry and Maurits!
- Has thanked: 17970 times
- Been thanked: 8904 times
Sounds like a lot of subtle detail to be seen on the disc, glad you had the seeing for it
Better yesterday than today. Today I am under an overcast cloud deck with drizzling rain.
I must admit James, that the amount of rain over the last few day where London itself has had much flooding, but it has helped me to complete the ground-work for the new mini-obsy, with just one small job left, so the cooler and wet-weather has its' advantages.
EGRAY_OBSERVATORY wrote: ↑Tue Jul 13, 2021 5:08 pm I must admit James, that the amount of rain over the last few day where London itself has had much flooding, but it has helped me to complete the ground-work for the new mini-obsy, with just one small job left, so the cooler and wet-weather has its' advantages.
Terry,
You have taken that cloudy rainy weather to wise use!
- Ivan
- Has thanked: 3479 times
- Been thanked: 2260 times
James, thanks for keeping us posted. Unfortunately, I am writing this post quite late, but better late than never. AR12842 I was also able to clearly see in Ha. AR12841 I still don't understand that I see a stain or processing artifact
Ivan
PS I am always looking forward to your phrase at the end, will you see granulation or not.
Ivan
PS I am always looking forward to your phrase at the end, will you see granulation or not._Ivan
That usually depends on seeing and clouds!
